0 Members and 1 Guest are viewing this topic. Read 38812 times.
(1) I can't tell if you're serious... a 10" sub can only go so low. There is material below the...maybe...25-29 hz you're hitting with that sub. Since you said it has 100w behind it, I'd guess not below 30 hz. It also can not reach the decibel levels many users would want.(2) you're happy with your setup, awesome! There's better out there, but at some point, it costs more money. Do your wallet a favor and avoid hearing better.
The OB multiplier is a myth, so much depends on placement, EQ, effective baffle size, etc.I guess this thread got off track. Since it already is, it would be "nice" if there were some reasonable points of agreement on how to present "bass." I feel that the decay times in the bass integration guide (which I think I linked already) are a good item for that list.
I agree John, the room should be as non-resonant as possible below the Schroeder frequency. This reduces objectionable bass overhang and allows a more accurate reproduction of the source material.As a rule bass bloat, overhang and boom do not occur during a live performance. Taking care bass resonance problems also greatly improves the home theater experience as well. Speech is more intelligible, gun fire and explosions are crisper with improved attack which greatly increases their realism. Scotty
Scotty:Several years ago I saw Eric Clapton at the Staples Center in Los Angeles. Has 13th row floor seats. The opening act was Doyle Bramhall III's band (whom I know personally) and their mix was horrible, everything was muddy and boomy and I thought it was going to be just as bad for Clapton. To my guests and my surprise Eric's sound was amazingly good. Nathan East was his Bassist and there was no problems....same for the late Billy Preston on the Hammond B3. Needless to say, there were many below 40hz moments that night! The venue is critical, but so is the guy on the mixing board. Jim
(1) Assuming your speakers are at the other end of the room (2) from where your measurements were taken, I would hazard to guess that you were taking your measurement at the point in the room where the standing wave at the frequency you elected to measure was at a maximum. (3) If you walk forward from the rear wall towards the front wall you will no doubt measure a series of peaks and nulls at various frequencies below about 125hz and extending down to the lower frequency limit of your combination of speakers and room dimensions. If you place a sub in the rear of the room you can minimize or eliminate the peaks and nulls that exist in the room. Scotty
...I have always felt that bass is the bones; midrange, the flesh; and treble, the skin of music. Without good bone structure, you just can't get good looks... ...I can't stand boomy bass but I can't stand lack of bass either. So for me, I need to go below 40hz every time I turn my system on,
Are you saying that the fact of reduced output (for a given placement, amp power and so on) is a myth or that 4 is too large a factor?
