BDP-1 Software Update Experts - I Need Some Help!
0 Members and 1 Guest are viewing this topic. Read 2375 times.
mrderrick
« on: 9 Jun 2012, 09:43 pm »
First, I have been in contact with James and he has suggested that I contact Chris on Monday next week to take a deeper look into what I am experiencing.
I am hoping that somebody may have worked through the same issue and can lend some advice or possibly recognise that I may have made a mistake somewhere along the line.
I requested and received via email the Firmware bin. file to upgrade the BDP-1 along with the installation instructions.
When I get to the point of selecting the bin. file from my desktop and hitting the "Update" icon, nothing happens.
The instructions say that the update can take 20 - 30 minutes depending on the server load, I had no action for 1 - 8 hours.
I have no problem that I know of with Firefox and the bryston-bdp-1.local connection.
I am using a PC with Windows XP.
Do I have to have  software installed that can open the bin. file?
Any insight would be greatly appreciated.
Bob D
  • The Demo is Everything!
    • http://www.bryston.com
Re: BDP-1 Software Update Experts - I Need Some Help!
« Reply #1 on: 9 Jun 2012, 09:59 pm »
Hi Bob,
1. Does the BDP-1 have an IP address?
2. Do you have Bonjour for Windows installed on your computer?
james
mrderrick
« Reply #2 on: 10 Jun 2012, 12:21 am »
Hello James,
The Network info displayed on the BDP-1 home page is as follows;
Network - DHCP
IP Address - 192.168.1.34
Net Mask - 255.255.255.0
Gateway - 192.168.1.1
Should the Network be set as DHCP or Static?
On the BDP-1 screen 192.168.254.254 is displayed.
I do have Bonjour for windows installed and I did re-install it just to be certain that it was current. ( I am not certain if it is working though )
When I hit the update button, it appears as though data is being transmitted, abit slow though. ( blink blink pause, blink blink pause go the router LEDs )
I get the feeling that there is a minor ( though important ) detail that I am missing in the process.
Thanks for responding again!
Bob D
« Reply #3 on: 10 Jun 2012, 12:40 am »
The 192.168.254.254 means the BDP does not have an IP address.
James
mrderrick
« Reply #4 on: 10 Jun 2012, 01:22 am »
OK James,
Does that mean that I definitely have to contact Chris?
Bob D
« Reply #5 on: 10 Jun 2012, 01:24 am »
OK James,
Bob D
Hi Bob
Yes sorry I am not network savy - in fact I suck at it :duh:  Maybe others here can help :scratch:
James
« Reply #6 on: 10 Jun 2012, 01:30 am »
Bob
Just thought of something - try unplugging the power from your router for a few seconds and then repower. That will force the router to assign new IP addresses.
Then see if the BDP front panel shows a new address
James
PS .... 2-1 New Jersey :thumb:
mrderrick
« Reply #7 on: 10 Jun 2012, 09:57 am »
James,
The BDP-1 display does match the IP address on the Bryston homepage now.
192.168.1.34
Bob D
« Reply #8 on: 10 Jun 2012, 06:43 pm »
James,
192.168.1.34
Bob D
Ok try using that IP address to do the update. If all else fails Chris should be able to help tomorrow.
James
mrderrick
« Reply #9 on: 11 Jun 2012, 09:16 pm »
I got in contact with Chris today.
He took control of the situation and all is well.
The software update was a success.
Thanks to James and Chris!
