0 Members and 1 Guest are viewing this topic. Read 6556 times.
Maybe I should run them without a sub and try that... set to small.
You might also want to look into some bass traps. We all can use them.
I think my only choices are small or large for the speakers....Is it possible to run the sub for HT and just the speakers for music? just trying to understand how this works...
The ST's and sub are independently connected to the receiver? And if so, when set to large and the sub is off in Direct mode you do not get adequate bass? If so, then the room is the issue.What are the overall dimensions and where are the openings to other rooms?The ST's can dig pretty deep in full range operation in modest sized rooms. Any dac in the loop?
ok will try to answer all.room is a sunken living room appx 18x20 w the speakers on the far wall away from the opening. There is pic on my ST thread, sorry cant post here at work. floor is floating HW. there is a cove lighting sytem on the ceiling that runs the perimeter of the 9 foot ceiling. appx 1 foot deep, 3 feet wide. Yes i use a DAC sometimes to play my FLAC library, but was using Jims CD in my Pio Elite BR player.No i cannot sep modes on my SC35. I have 6 memory settings for the EQ i can switch between, but cant sep out the sub. If i was to take out the sub, would i just wipe the memory of the Pio and start from scratch? i notice a lot of people listen to music w just the STs... Nuance sent me an XLS plot to plot out test tones ..http://www.avsforum.com/t/939744/the-official-salk-sound-owners-and-discussion-thread/7380#post_22102994 post 7388thank you for all your suggestions... still new to the Audio world and have a lot to learn...Thank you, Frank
