Songtower Set Up Questions
0 Members and 1 Guest are viewing this topic. Read 6560 times.
Nuance
Re: Songtower Set Up Questions
« Reply #20 on: 7 Jun 2012, 12:27 pm »
for this I didnt use the sub, just the STs.
I listened to some music this way and it seemed a bit better, but still not where it probably should be.
I guess room treatment would help that? just not sure where to start...
thanks for your input though :)
Frank
Room treatments aren't going to help that far down low in my opinion; They'd need to be several feet thick.  Try crossing to the subwoofer and running your speakers "small," then re-measure.  The best placement in your room for great imaging and sound stage capabilities is usually not the best placement for bass, which is why using a subwoofer is helpful; you can place the sub where the in-room bass response is the best.  If you want to continue listening in 2.0 full range configuration, try moving your speakers a bit (6 inches can make all the difference in the world).  Again, the goal is an even response.
wyowolf
« Reply #21 on: 7 Jun 2012, 01:13 pm »
OK will try that. So the room is causing the dips in the graph correct? Will try moving the speakers a bit and also play with the sub placement.
thanks for all your help!
Frank
