my Tempesta DIY
0 Members and 1 Guest are viewing this topic. Read 9368 times.
vortrex
my Tempesta DIY
« on: 30 May 2012, 10:33 pm »
the "before" shot with the drivers dropped into place.  I had the cabinets made to the same spec as the rectangular PE ones.  they still need a fair amount of work before I can get to doing the finish, but hopefully in a couple weeks they'll be done.
sonicxtc
Re: my Tempesta DIY
« Reply #1 on: 30 May 2012, 10:38 pm »
They look great. I hope to follow this thread.
May I ask how much it cost to have the cabinets fabricated?
Thank you.
EDS_
Re: my Tempesta DIY
« Reply #2 on: 30 May 2012, 10:55 pm »
Totally spectacular!
jonbee
Re: my Tempesta DIY
« Reply #3 on: 30 May 2012, 11:51 pm »
An understatement.
pawsman
Re: my Tempesta DIY
« Reply #4 on: 31 May 2012, 09:56 am »
Spectacular indeed!! Who did the cabinets? Are you going with a clear finish?
pawsman
vortrex
Re: my Tempesta DIY
« Reply #5 on: 31 May 2012, 04:37 pm »
the cabinets were built by http://www.signatureaudiolabs.com/ and cost $1200 - custom design, all holes cut, No-Rez installed, and finish sanded.  I'll be leaving them bare ply, but might put a light walnut stain on to warm them up a bit without ruining the stacked ply look.
saeyedoc
Re: my Tempesta DIY
« Reply #6 on: 31 May 2012, 05:41 pm »
Have you been able to listen to them yet?
Any work on when your Cirrus is coming?
I was going to wait on your comparo, but jumped ship and ordered some Supercharged Songtowers in an unusual veneer.
vortrex
Re: my Tempesta DIY
« Reply #7 on: 31 May 2012, 06:26 pm »
no, as I said, 2 weeks or so.  they are empty unfinished cabinets at this point.  no current update on the Vapor.
saeyedoc
Re: my Tempesta DIY
« Reply #8 on: 31 May 2012, 07:22 pm »
Ok, sorry, I saw the pictures with the drivers in place, didn't realize you hadn't finished them yet, thought the work you had left was just cosmetic.
By the way, they look great, I think you made a wise choice. I couldn't bring myself to buy a $4k speaker in a pre-built cabinet, maybe if I was 30 years younger and single.
vortrex
Re: my Tempesta DIY
« Reply #9 on: 31 May 2012, 07:39 pm »
weren't your new ST's $4k?
saeyedoc
Re: my Tempesta DIY
« Reply #10 on: 31 May 2012, 08:29 pm »
$3800/pr including the upgraded veneer, a spalted beeswing makore. High WAF, I let her have input on the veneer and the SCSTs will take up less floor space than a stand-mount, they are 1/2 as wide as my Vandersteens and no deeper.
vortrex
Re: my Tempesta DIY
« Reply #11 on: 31 May 2012, 08:51 pm »
yeah, those are going to be great speakers too.  I almost went with SC ST's in the beginning but decided I wanted to try a stand mount with better drivers.  I definitely like the fact there is less depth needed though.  the Tempesta's look so beefy next to my SongTowers.
saeyedoc
Re: my Tempesta DIY
« Reply #12 on: 31 May 2012, 09:03 pm »
Didn't realize you have the SongTowers also. So how many pairs of speakers will you have once you get your Cirrus?
vortrex
Re: my Tempesta DIY
« Reply #13 on: 31 May 2012, 09:36 pm »
would only be 3 total.  I'm going to list the ST's for sale soon, when I am closer to having the Tempesta's ready.
saeyedoc
Re: my Tempesta DIY
« Reply #14 on: 31 May 2012, 10:03 pm »
Are you thinking of just keeping one of the Tempesta or Cirrus or both?
I love the construction of stacked ply, looks very robust. Given what Ryan's doing with his cabinets, I bet they will be even more substantial. Whether that really makes a difference in the sound,who knows. It would be interesting to compare your Tempesta to one with the standard cabinets. Regardless, they sure look more interesting then the pre-built ones.
vortrex
Re: my Tempesta DIY
« Reply #15 on: 31 May 2012, 10:13 pm »
I'll keep one pair, after spending some amount of time with both.  I want this to be the end of the road for speakers.  I think this will mostly come down to whether I like 2 or 3-way best.  obviously both are top notch speakers in this price range (and probably much higher too).
I don't know how much the cabinets will add to the sound.  to be perfectly honest, I did the stacked ply for the Tempesta for aesthetics mostly.  if there is a sound improvement, then that's a bonus.
the front and rear is 1" thick and the sides are about 1.5" thick.  there are 3 of the horizontal braces inside.  the braces are a little bit different in the pic, the edges are nicely rounded off in the actual cabinets.
jonbee
Re: my Tempesta DIY
« Reply #16 on: 31 May 2012, 11:57 pm »
Well, it should be a most interesting, classic matchup, IMO. I hope you report what you find along the way.
ricardojoa
Re: my Tempesta DIY
« Reply #17 on: 4 Jun 2012, 05:22 pm »
$1200 for each or a pair?
vortrex
Re: my Tempesta DIY
« Reply #18 on: 4 Jun 2012, 05:28 pm »
for the pair.
ricardojoa
Re: my Tempesta DIY
« Reply #19 on: 4 Jun 2012, 05:31 pm »
thanks, please dont forget to report of the two speakers u got now  ;)
