BDA-1 USB 192/24 ?!?
0 Members and 1 Guest are viewing this topic. Read 36822 times.
Marius
Re: BDA-1 USB 192/24 ?!?
« Reply #120 on: 16 Nov 2012, 04:53 pm »
I understand the proximity-issue in the USB interface. I think. to be honest I would have thought that either the front or back panel, would be just as far away from the receiverchip, since it is a rather small box your designing.
By the way, I did not mean to ask for a replacement of the backpanel usb-port, just an extra frontpanel usb port, to enable easy hooking up of a mobile computer. With a usb-port only on the backpanel, that is just that bit more uncomfortable.
But, as always, lets opt for optimal Bryston sound.
Have you considered the DSD-option in the BUC-1?
Marius
Hi Marius,
OK I think we are confusing the BDA-2 DAC vs the USB Interface.  With the USB interface you want the USB connector to be as close to the USB Receiver chip as possible.  In the BDA-2 DAC you want the USB circuit to be as close to the DAC as possible.
james
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #121 on: 16 Nov 2012, 05:31 pm »
Marius
Hi Marius,
The USB Interface is not a small box - it is 1/3rd the size of the BDA-2.
james
Marius
« Reply #122 on: 16 Nov 2012, 05:43 pm »
oops, sorry James. No offence meant  :oops:
Hi Marius,
james
« Reply #123 on: 16 Nov 2012, 05:51 pm »
Hi Marius,
None taken sir - it is just I want to make sure customers understand this in not your typical pencil shaped USB powered interface.
james
Aramys
« Reply #124 on: 25 Nov 2012, 11:40 am »
Is this the chip in BDA-1? - http://www.cirrus.com/en/pubs/proDatasheet/CS4398_F1.pdf
Yes it is. And it is DSD capable as it seems (although I'm not electronic chips expert).
Marius
« Reply #125 on: 24 Jan 2013, 04:48 pm »
these might be an inspiration for the Bryston USB interface: http://www.chordelectronics.co.uk/products-info.asp?id=74 and http://www.chordelectronics.co.uk/products-info.asp?id=85 both able to play DSD over Usb.
fingers crossed,
Cheers
Marius
