BDA-1 USB 192/24 ?!?
0 Members and 1 Guest are viewing this topic. Read 36683 times.
Phil A
Re: BDA-1 USB 192/24 ?!?
« Reply #100 on: 1 Oct 2012, 04:29 pm »
I do not think the BDP-2 will be able to pass DSD.
james
James - even passing it over to the BDA-2 via PCM? - e.g. http://www.dcsltd.co.uk/page/assets/DSDoverUSB.pdf
klao
« Reply #101 on: 1 Oct 2012, 04:53 pm »
The Auraliti PK 100 that share some similar platform/hardware to the BDP-1 can somehow play the DIFF file now.  I'm not sure if it's direct DSD signal passing through its BNC connection, though.
http://www.auraliti.com/Store.html
MSB Tech's new firmware also enables their DAC & universal transport to play DSD through all their inputs / outputs.
So, I'm wondering if Bryston can work around the software part to do the same.  Cheers.
Mastadon
« Reply #102 on: 1 Oct 2012, 11:18 pm »
Hello.  I hope it's acceptable to ask this question here.  It seems to be related to the thread.  I'm having issues with a BDA-1 and 192/24 as well as other files.
I have imported a few 24bit flac files at sample rates of 44.1, 88.2 and 192 Hz into Decible on a MacBook Pro.  When I connect to the BDA-1 via USB the Sample Rate indicator on the BDA-1 lights up at 44k for each of these files. The Lock LED also lights up.  When I connect to the BDA-1 via the optical output on the MacBook Pro the BDA-1 Sample Rate indicator lights up at 48k for these same files.  Again, the Lock LED lights up.  What is happening here?  Shouldn't the BDA-1 be indicating 88.2 or 192 Hz signal for those files?
The sound is good but I'd like to understand what's happening here and what I might be missing?
David
gdbalp
« Reply #103 on: 2 Oct 2012, 12:23 am »
Hi,
Is there any software for ripping SACD (DSD) discs :green:?
Ciao, Luigi
larevoj
« Reply #104 on: 4 Oct 2012, 12:10 pm »
Phil A
« Reply #105 on: 4 Oct 2012, 12:23 pm »
Hi,
Ciao, Luigi
There's a whole thread in the hi-rez music circle about which PS3s and which firmware can be used
Phil A
« Reply #106 on: 4 Oct 2012, 12:26 pm »
Hi,
Ciao, Luigi
Here's the thread - http://www.audiocircle.com/index.php?topic=95396.0
klao
« Reply #107 on: 4 Oct 2012, 01:34 pm »
MSB Tech claims you can use thier universal transports to rip SACD's too.
I'd go with much cheaper PS3, though.   :P
gdbalp
« Reply #108 on: 5 Oct 2012, 03:09 am »
Hey Phil,
Great news, there is a way to decode SACD, but you need a PS3...
Is there any commercially available software for ripping SACDs?
Ciao, Luigi
Phil A
« Reply #109 on: 5 Oct 2012, 03:22 am »
Hey Phil,
Ciao, Luigi
Not aware of any.  The hi-rez music circle would have more information though
ted_b
« Reply #110 on: 5 Oct 2012, 03:38 am »
Hey Phil,
Ciao, Luigi
PM me
Marius
« Reply #111 on: 15 Nov 2012, 04:42 pm »
HI James,
Is there any news on the usb converter? When will it arrive and what will be the final specs?
Marius
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #112 on: 15 Nov 2012, 05:15 pm »
HI James,
Marius
Hi Marius,
yes Dan is working on it now and I hope to have it ready in about 2 months.
james
james
bobNL
  • Some say he's a purist
« Reply #113 on: 16 Nov 2012, 08:28 am »
Also, have you decided on a name yet?
He asked with great anticipation   :dance:
Bob
Marius
« Reply #114 on: 16 Nov 2012, 08:47 am »
exciting!
any chance of a front usb receptacle? Have you decided on the DSD support yet, maybe have a look how Cord supports DSD in its new Chordette?
looking forward to it as a bda1 owner....
Marius
Hi Marius,
james
james
« Reply #115 on: 16 Nov 2012, 11:30 am »
Bob
Thinking BUC-1
James
bobNL
« Reply #116 on: 16 Nov 2012, 01:32 pm »
Seems to be good news for Marius  :thumb:
Re: BDA-2 DAC
« Reply #54 on: 24 Oct 2012, 02:55 pm »
Hi James,
Could you still add a front USB port also (not an extra, but doubling the back port)?
The back port is great for fixed aparatus, (like a new MacMini for example...) but a front port would make life much easier on those that bring their laptops to play more infrequently (is that an english word.. ) and connecting to it so much easier. Positioning the BUC-1 more elegantly too.
Marius
« Reply #117 on: 16 Nov 2012, 04:00 pm »
Re: BDA-2 DAC
Hi James,
Marius
Hi,
No we have looked at it and moving the USB to the front and that far away from the DAC causes performance issues.
james
Marius
« Reply #118 on: 16 Nov 2012, 04:19 pm »
Ok thank you James,
Now we'll have to have use a USB cable to come to the front of the AudioRack to connect it to the Laptop (in my Case). Won't that impact performance even more ? Sorry for not understanding, but what do you mean with the longer distance to the DAC? U mean the BDA? Or the Chip in the BUC-1?
Marius
Hi,
james
« Reply #119 on: 16 Nov 2012, 04:36 pm »
Ok thank you James,
Marius
Hi Marius,
OK I think we are confusing the BDA-2 DAC vs the USB Interface.  With the USB interface you want the USB connector to be as close to the USB Receiver chip as possible.  In the BDA-2 DAC you want the USB circuit to be as close to the DAC as possible.
james
