0 Members and 1 Guest are viewing this topic. Read 36672 times.
James,any news on the update for the BDA-1's ability for 192/24 via USB??thanks,al.
...ok, thanks. one more question:the SP3's USB is modular and the BDA-1's is not, correct?!?al.
Correct - but with the USB we are developing we are working on a way to retro-fit the current BDA-1's.james
That's great! Btw, James do you think ideally its the best to keep USB out of the DAC??
James, don't you think the BDP-1 digital Player with the BDA-1 DAC is the better approach?? Also would there be proper isolation at the USB interface from computer source?
Hi,Yes I do but some want to be able to use their Laptop as their source component.james
That's a reality now and will certainly make the BDA-1 more appealing. Any idea how much will the upgrade be for existing BDA-1 owner?
Hi Too early to say - we are still looking at what is possible and how best to implement it. james
James - any additional thoughts/developments on a USB upgrade to existing DACs? CES is around the corner and I figured it might be on the table?
We are going to offer an external unit that will connect to the BDA-1.james
James, thanks. Do have any inkling as to timing? A few months? A year?
