BDP1 & Crestron remote
0 Members and 1 Guest are viewing this topic. Read 2391 times.
kostisgva
« on: 27 May 2012, 11:57 am »
Hello,
Just asked James about it, he will look at it(thank you James!).
Anyone from here controls the bdp1 with a Crestron remote? I am about to make a new programming and my installer cannot find the crestron module for it. For the sp3 we are good though!
Thanks in advance for our help!
terrycym
Re: BDP1 & Crestron remote
« Reply #1 on: 27 May 2012, 01:30 pm »
You can get a Bryston remote that mimics the front panel controls, can the Crestron learn that?
unincognito
    • bryston.com
« Reply #2 on: 27 May 2012, 02:32 pm »
Hi,
Does your installer plan on controlling it via IR, Serial or Network?
Chris
kostisgva
« Reply #3 on: 27 May 2012, 02:42 pm »
Hi,
Chris
Hi Chris,
Ideally RS 232 then IR, is it possile by network?
Thank you
kostisgva
« Reply #4 on: 27 May 2012, 02:44 pm »
Sure guess it could, which remote should I buy?
Thank you!
terrycym
« Reply #5 on: 27 May 2012, 04:22 pm »
The BR2 remote control is available (see Accessories in Other Productsin on the Bryston web site)
http://bryston.com/products/other/BR2.html
It's rather expensive for what you'll be getting out of it though.
To tell you the truth, you're better off with a iPAD, iPhone or iPod touch and use either the free mPOD or the paid for mPAD
http://www.katoemba.net/makesnosenseatall/mpad/
If you have an Android phone, you can use that instead but I haven't seen the Droid interface so I can't comment on that.
I use mPAD and I'm very happy with that.
unincognito
    • bryston.com
« Reply #6 on: 28 May 2012, 01:51 am »
Hi,
If yor crestron setup has a network interface it would be possible to use the crestron to control the bdp.  If your interested I can post some basic stuff.
IR is the only way to control power for the bdp-1, IR and the triggers on the back.
Also I believe crestron has an app available fOr iPhone/iPad to use them as a crestron panel.
I'll post the rs232 and ir codes Monday once I get into work.
Chris
kostisgva
« Reply #7 on: 28 May 2012, 04:28 pm »
Thank you! I am also using mpad, i am also very happy with the new max2!
I simply want to use one remote for my system! Hopefully my installer will work something out.
kostisgva
« Reply #8 on: 28 May 2012, 04:31 pm »
Hi,
Chris
Thank you Chris,
Yes it has network interface, thank you in advance for posting both codes, i will give them to my installer. For the power I guess that I will use the triggers and turn it on at the same time with the SP3.
Kostis
