0 Members and 1 Guest are viewing this topic. Read 3713 times.
So, I'm wading into the Salk waters by going the used route. My choices are HT3's or HT2-TL with HTC. My gut says go with the 3 way box but I do have sub(s) on hand, so what say ye?I can not hear/see the HT3's, but am going to listen to the HT2-L's in the a.m. I'm sure I'll be impressed.Music is classic/current pop, rock, contemporay, blues.Front end is very modest Integra 886 into a reworked Sunfire Cinema Grand. Room is 18x20. Can only get the speakers about 3' from the wall behind them and 3-4' from the side walls.
As the owner of HT3s I would suggest you go with the HT2-TL. I don't believe you will regret your decision.
