0 Members and 1 Guest are viewing this topic. Read 27023 times.
Thanks guys. You're making my life simpler! It sounds like the difference between 88 and 84 sensitivity is huge. I guess that makes sense when people talk about doubling power for 3db, though I don't know if that is the same db when talking sensitivity.
Both speakers are really nice and I don't think you can go wrong with either. Those big Emotiva amps should be able to drive the HT3's without any issues. If I had to choose between the two, I'd get the HT2's and have Jim build you a couple matching subs. This would require a bit more effort but would allow you to dial in the bass more precisely and add some EQ. Some people don't have room for the extra subs and there may be a WAF issue with external subs. Also, please keep in mind, companies like Salk are very honest with their specifications. Some commercial speaker manufacturers fudge their numbers to make their products seem more efficient than they really are. I'm pretty sure the HT3's are not as inefficient as you might think. Both the HT2TL's and HT3's are very impressive looking and well designed. Good luck with your decision.
While they weigh and cost a bit more, the SoundScape 8's should be considered as well. They don't place as much demand on amplification (being roughly the same sensitivity as the HT2-TL's) and they are very easy to place in a room (due to the horizontally-opposed passives). They are also slightly narrower than the HT3's which some people might find advantageous.- Jim
I was in the same boat a couple months ago...on the fence between HT-3's and HT2's. I always wanted HT3's, and after SongTowers, HT1-TLs and Songbirds, figured they made the most sense as an upgrade for the 'last' speaker I'd buy. After corresponding with Pete, Jim and Nuance, I decided to go with HT2's though. Easier to place in a room and I didn't have to invest in big watt amps. (Though now I probably will end up with a bigger amp anyway!)
The 8's are the best of the lot soundwise.The HT3 will continually want more power and if you don't drive your system hard will be okay with an okay amp. I always want the best possible and to push the limits and I could never hit the limits with the HT3 because of their power hungry nature. That's me.If you can swing the 8's then do it.
Come on now! How about something about how they sound and how you like them and how your decision is sitting with you!"they made the most sense as an upgrade for the 'last' speaker I'd buy." Famous last words, eh? [/quoteI don't have them yet...hopefully they will be done next week.Yeah, I say that but my wife knows better.....
Thanks Pete, they are back in serious consideration.
Hello, my name is Mike (Hiiiiiiiiii Miiiiiiiiiiike) and I would just like to publicly admit I'm jealous of all of you guys who have the financial resources to purchase HT2-TL's and up in Jim's lineup Maybe someday I'll be able to upgrade from my ST/RT's with the LCY.
