Audio/Video Gear and Systems
Owner's Circles
The nOrh Owner's Circle
jqp
power needed for nOrh 4.0 ceramic
0 Members and 1 Guest are viewing this topic. Read 1646 times.
ckeyes
Newbie
25 May 2004, 03:06 am »
I have low powered amp, Sansui integrated AU-217
Am considering purchase of nOrh 4.0, but wonder
if I have enough power. I've read that they do best
with a lot of power??
Marbles
25 May 2004, 03:13 am »
They will do fine with the AU-217 unless you have a really large room or like to listen VERY loud.
jptang
4.0 power
Reply #2 on:
26 May 2004, 05:45 pm »
i've run my 4.0s with the little 9 watt pc nOrh se9 and it was ample for my bedroom.
I've also used more powerful amps with them and they will play loud. You probably have plenty enough power for them.
ckeyes
Newbie
Reply #3 on:
5 Jun 2004, 06:18 pm »
thanks for the responses - I should just go ahead and order them
you can quickly drive yourself crazy poking around reviews
on the internet for best inexpensive speakers now I'm
considering Ascend Acoustics CBM-170 or EPOS els-3
Owner's Circles
jqp
