Favorite SET output tube
0 Members and 1 Guest are viewing this topic. Read 39778 times.
Freo-1
« on: 23 May 2012, 12:11 am »
OK, what is your favorite SET output tube?  Are you a fan of the directly heated triode, or something a bit later in development?
Each tube type  has a sonic signature that goes with the design, so looking for folks to pass along just what it is about their favorite tube that draws you into the music.
Re: Favorite SET output tube
« Reply #1 on: 23 May 2012, 12:18 am »
Apart from the big DHT Triodes, I like the 6C33 by the sheer power, great sound and low output impedance, which means a low price output transformer, or even OTL.
Iam out of Pentodes, PushPull or UltraLinear, but I like to listen it in the friends house.
DaveC113
  • ZenWaveAudio.com
« Reply #2 on: 23 May 2012, 12:54 am »
My amp runs el34 and kt88/6550s, either UL or Triode strapped.
I run el34s in triode mode 99% of the time. The kt88/6550s in UL do put out more power though, that's what I'd use if I wanted to play dance music real loud.  :green:  That doesn't happen very often.
As far as the DHTs, I'd like to try them but money is an issue. I built the amp I'm using right now myself, and I'd need to spend over $2k to top it, otherwise I feel I'll only get a different amp that's not necessarily better. Maybe some day...
JackD201
« Reply #3 on: 24 May 2012, 02:46 am »
GM70
was RCA 2a3 but I don't have the speakers for them to do their best.
56oval
« Reply #4 on: 24 May 2012, 02:55 am »
Hi
I really like the 45 but very low powered ,next 2a3 and 300B abit more juice to play with .And then theres the 845 ,211 and I liked the sound of the 4212 .
If you need more grunt you can always PP the triodes  :) .Or  go active using low powered triodes  8).
Cheers
Quiet Earth
« Reply #5 on: 24 May 2012, 03:18 am »
Yeah, that's sort of what I was thinking.
I have heard the 45, the 300B, the 211, and the 845 output triodes and I like them all. I have stuck with my 300B for a long time because, like Goldilocks, it's not too much and not too little. It's just right.
I am fascinated with the beauty and rightness of the 45, but I fear that it may not be enough power for me most of the time.
I am awestruck by the power and control of the 211, but a little voice inside of me says that I would hardly ever excersize it. That's a lot of heat to just sit in idle.
The 300B seems to be a good place for me. Still, I sometimes wonder about a single 2A3. Would that get me closer to a 45 but still have enough umph? I don't know.
All in all, I think that what makes one output tube stand out more than the other is really the amplifier that it resides in, not the output tube itself.  But I get the point of this post. Which flavor do you like? That's a tough one. They are all a little different.
« Reply #6 on: 24 May 2012, 03:29 am »
Hi
Cheers
Hello,
What a great thread. GM70 and 212E are big contenders in the power output position, one cost 18euros other 2K dollars(Gulp!).
At least the 212 socket is cheap: http://www.ebay.com/itm/4-Pin-Giant-Tube-Socket-for-4212E-212E-Tubes-/380355997471?pt=Vintage_Electronics_R2&hash=item588efbef1f
Do you would inform us how is the 212E or 4212E sound??
56oval
« Reply #7 on: 24 May 2012, 03:56 am »
Hello,
HI
If you like the sound of most of the big triodes I think you will like it but do you want to play around with HV .Heres an amp a mate built for a friend of his the HT @ 1300VDC .
 The trouble with tube gear is you could use the same output tube but use different circuits and have a different tonal quality ,I think its a case of pic your poison and match with the speaker with an easy load for the amp .
Like the KT88 drive on the left  :) .
Heres my mates blog  http://web.me.com/blackart/Site_2/Blackart_Audio_Blog/Blackart_Audio_Blog.html  and some of the work he does .
Lucas drew up all my circuits and makes all the iron I need so I can build my amps .
Cheers
56oval
« Reply #8 on: 24 May 2012, 03:59 am »
Nice glow
Heres my mates blog
He's drawn up all of my circuits and has made all the iron for my projects .
 SOme 300B's I've tried for the amps
CHeers
56oval
« Reply #9 on: 24 May 2012, 04:01 am »
Double post  :?
gsm18439
« Reply #10 on: 24 May 2012, 09:54 pm »
I went from 45 to 2a3 to 300b. I am currently using Takatsuki TA-300b; if you like the 300b, you need to hear the Takatsukis.
« Reply #11 on: 24 May 2012, 10:02 pm »
56OVAL: Thanks for the nice photos.  I read in Japan the AD1(now ressurect by Emission Labs) is the tube rated best sound by audiophiles, even better than 2A3 & 300B.
« Last Edit: 24 May 2012, 11:06 pm by FULLRANGEMAN »
Quiet Earth
« Reply #12 on: 24 May 2012, 10:41 pm »
Got a link with more info? Are these the rare and unobtainable tubes going for two grand USD???
gsm18439
« Reply #14 on: 25 May 2012, 01:35 am »
http://www.amtrans.co.jp
56oval
« Reply #15 on: 25 May 2012, 01:42 am »
Hi gsm
Maybe at a latter stage I might track down a pair of TA-300b but their as little bit rich money wise for me at the moment  :) . I believe circuits can make more an an improvement than just the glass .My tweeter 300B SET's have 2 power supply's and 2 chokes  :) and the 300B SET's running the midrange has 3 power supply & 10 chokes per channel  :green: ,irons good for you  :thumb: .
I have a pair of PP amps to build for the bass drivers so no money for expensive 300B's  :cry: .
Cheers
Mal
Poultrygeist
« Reply #16 on: 25 May 2012, 11:07 am »
I once heard the 2a3 described as a beautiful sophisticated but delicate woman while the 300b was an athletic 20 year old male full of vim and vigor.
« Reply #17 on: 25 May 2012, 11:04 pm »
In my country the 2A3 is called the Triode of Emotion, which is very appropriate.
Scott F.
« Reply #18 on: 25 May 2012, 11:31 pm »
I've done 45s, 2a3s, 300Bs and 211s. I still run 2a3s and 300Bs but my favorite SET tube is the 50. It's lovely. Lush yet detailed. Lots of body, delicate clean highs and weighing in at around 5 watts works right fine with my HiEff speakers. In the right circuit with the right parts, there is no better...to my ears. If I had to use one word to describe the 50 it would be liquid.
Good luck finding NOS ones. They're getting pretty rare. One of these days I'll convert a spare pair of 300B monoblocks I've got to 50s...one of these days  :duh: :thumb:
« Reply #19 on: 25 May 2012, 11:43 pm »
I unaware you are a tube amp builder, good to know it, maybe useful in a future project.
Do you already made a 6C33 SET??
