0 Members and 1 Guest are viewing this topic. Read 12188 times.
Wouldn't mind test driving one of these.
However I would spend the $16 more for the corded version (same web page, just click on the box to the right) as it drains static away
What brush do you guys recommend?Thoughts?
That good huh?
Do you know if there is a 1 meg (or similarly high value) resistor built into the cord?
It's then quite easy to see why Vacuum Record Cleaning machines are so popular. The cleaning solutions lift the debris into solution and the vacuum lifts it all off.
Do I need a vacuum cleaner? NO! I can build one cheap if I need one. But I don't think I do need one at all.
(1) In my case a vacuum was night and day.(2) Washing in the sink with soap and brushes and a distilled water rinse does not even come close. (3) I suspect that the "I don't need one" assessment is not for those looking for for the quietest playback... (4) and instead of "thousands", vacuum cleaning can be had new for about $150.
