0 Members and 1 Guest are viewing this topic. Read 12183 times.
I use a double row carbon fiber brush from Sleeve City. It's ok for surface stuff and static removal, but isn't stiff enough to get down into the grooves. http://www.sleevetown.com/record-brushes.shtmlIt's one of the cheaper ones at about $12.
Their inner sleeves are fabulou especially their Ultimate inners. I also love their sleeves that hold 2 LPs, that gets 50 LPs stored in quality sleeves for $13. Just got some LPs tha were in their nicest outer sleeve too. Very very nice outer. If only their shipping were cheaper.
Do you use their inner sleeves too?
Thanks Roscoe!I had a shipping quote for $14 for 500 inners. That didn't seem too bad to me.
I use a Watts Parastat I bought around 1977, it works great. The special fluid is long gone but a spray bottle with a distilled water/isopropyl alcohol mix works just as well. I can't imagine a record brush better than a Watts, different yes, but not better.From Vinyl Engine:"It has a central hand made brush supported by two velvet covered rubber pads."The brush is closely packed with over 30,000, 0.006" diameter pure nylon bristles finely pointed to an average tip radius of 0.00025" and firm enough to probe down into the groove without harming the record in any way."The short pile plush of the pads has a similar filament radius and will collect all dirt, dust and pollution dislodged by the brush.There happens to be one available on eBay:http://www.ebay.com/itm/vintage-1960s-The-PARASTAT-Model-MKIIA-Record-Cleaner-Cecil-Watts-Manuals-A-/390415580946?pt=Vintage_Electronics_R2&hash=item5ae694ff12Wayne
