0 Members and 1 Guest are viewing this topic. Read 7121 times.
With signals so small, I think you are going to need to get a shielded cable. Not much more to say about that. Not sure why you thought you could get around that requirement. That said, shielded cables with characteristics best suited for phono signals don't need to be expensive (but they sure can be).
Yeah, doesn't (usually) hurt to try. But some laws of physics can't be overcome. And you might hear a little "I told you so."But on the more helpful end of things, can you give an idea of your ideal budget for a cable so that some helpful suggestions can be generated?
Well Roscoe, as you probably already know, there has been more than one "inmate' over at AudioAsylum(Vinyl) claiming to be using unshielded IC's in a phono application with no problem. Hence the laws of physics had to momentarily be kicked to the curb. Only to of course rise up again and "hum" to me.
I like the Morrow MA3. Unfortunately, it's unshielded and despite its sonic advantages, the hum is a bit much.
There has been more than one "inmate' over at AudioAsylum(Vinyl) claiming to be using unshielded IC's in a phono application with no problem. Hence the laws of physics had to momentarily be kicked to the curb. Only to of course rise up again and "hum" to me.
Hi all,FWIW, I think the "Shielding" effect is all system and area dependent! I make lots of cables, none of them shielded and they don't hum a bit for me in my system and 99% of my customers and most have no hum issues. I think it's all due to RFI or EMI...
Hi.I suggest you to contact Morrow Audio to find out why it hums.Sorry, I disagree. Given built properly, an unshielded audio connect should NOT hum at all. Needless to say, it should not be too long. Otherwise, it'd hum even with triple shielding over it. Shielding generates extra conductor-shield capacitance, which rolls off HF. Sonically, the music sound compressed & less lifelike. I hate the sonics of shielded cables.Take mine for example, the 6 pairs of audio interconnects I DIYed & am using for years, are 4N pure solid silver conductors, NO shiled at all, including 2 pairs of interconnects from my TT to my 2 tube phono-preamps. No hum - provided they are built right!c-JPS: Pure silver cables sound superb. But you may ask how come pure silvercables are rarely available in the marketplace. One practical answer is: way way too costly to build & very dfficult to keep pure silver from tarnishing.Thank goodness, I know the way to overcome them.
