Unshielded IC's
0 Members and 1 Guest are viewing this topic. Read 7120 times.
cheap-Jack
Re: Unshielded IC's
« Reply #20 on: 1 May 2012, 07:46 pm »
Hi.
And if I were to contact Morrow, he would simply say  "buy my shielded phono cable"." My standard unshielded cables will be far more prone to hum in a phono application". This is just a guess of course, but I think I'm close.
Well, what else you can do if you really like Morrow's sound. Either replace it with Morrrow shielded ICs or return it for good & hunt for some other brandnames to trial & error.
That's the dilamma of audio consumers at large.
Thanks goodness, I know how to build pure silver ICs & power cords right so I don't need to go hunting around & spending big.
c-J
threadkiller
Re: Unshielded IC's
« Reply #21 on: 1 May 2012, 07:58 pm »
Now it's getting deep... :lol:
SteveFord
Re: Unshielded IC's
« Reply #22 on: 3 May 2012, 01:02 am »
I built some unshielded twisted silver interconnects and they don't hum with my old square motor WT unless I put in this one RCA tube in the preamp and then there is a slight hum.
Change the tube to another one and no hum.
Who knows.
threadkiller
Re: Unshielded IC's
« Reply #23 on: 3 May 2012, 01:33 am »
Hi Steve,
Sounds like that one tube is microphonic... It happens.
Often when the tube is long in the tooth.
