Sold: Class D CDA-254L and Pass Labs B1 with upgrades
0 Members and 1 Guest are viewing this topic. Read 2716 times.
gitarretyp
Both the amplifier and preamp are built into Par-Metal chassis
The amplifier is the Class D Audio CDA-254L but has several upgrades: increased power supply capacitance with Panasonic TS-HA caps bypassed with Nichicon Fine Gold and Sonicaps, upgraded rectifier, optimized output filter for 8 ohm loads (stock amp is optimized for 4 ohm loads), increased heatsinking, and a 5V trigger input (could easily be swapped for 12V).
The preamp is a DIY Pass Labs B1 buffer. I've used the extra 18VAC taps on the CDA-254L transformer to send power to the buffer, which is rectified and filtered inside the buffer. The buffer has 4 inputs and two outputs; one set of the outputs is XLR (not truly balanced) for easy use with a proamp. Also, the buffer has a stepped attenuator volume control with a bypass switch for HT use. The coupling caps are Clarity and russian teflon.
Asking $400 plus shipping for the pair.
« Last Edit: 29 Apr 2012, 10:26 pm by gitarretyp »
ejfud
Re: FS: Class D CDA-254L and Pass Labs B1 with upgrades
« Reply #1 on: 29 Apr 2012, 08:27 pm »
That's a nice deal for someone.
Excellent builds and good luck with the sale.
mrlittlejeans
« Reply #2 on: 29 Apr 2012, 09:16 pm »
gitarretyp - I sent you a pm.  I'll take them if still available.
persisting1
« Reply #3 on: 29 Apr 2012, 09:20 pm »
Someone is getting lucky  :green:
roscoeiii
« Reply #4 on: 29 Apr 2012, 10:19 pm »
Yeah, a great deal for someone here. Wow.
gitarretyp
Re: Sold: Class D CDA-254L and Pass Labs B1 with upgrades
« Reply #5 on: 29 Apr 2012, 10:27 pm »
The amp and preamp are sold. Thanks for everyone's interest.
