Bryston Headphone Cables
0 Members and 1 Guest are viewing this topic. Read 1970 times.
mkaiser
« on: 28 Apr 2012, 03:14 pm »
Hi James,
Has there been any more talk of you folks manufacturing your own headphone cables for the BHA1?
Mark
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston Headphone Cables
« Reply #1 on: 28 Apr 2012, 04:20 pm »
Hi Mark,
No other than we said we would be happy to modify the standard 1/4 inch phone jack plugs on most headphones to the 4 pin or 3 pin balanced connections the BHA-1 will allow for.
There seems to be quite an industry out there that does offer more elaborate cables for headphones though!
james
« Last Edit: 28 Apr 2012, 06:04 pm by James Tanner »
spinner
« Reply #2 on: 28 Apr 2012, 05:56 pm »
  What is the advantage, if any ,to changing from the 1/4 inch plug? :scratch:
« Reply #3 on: 28 Apr 2012, 06:07 pm »
Hi,
As long as the headphone cable has 4 wires you can then run the headphones Balanced through the front 4 pin or 3 pin x2 XLR connectors.  The BHA-1 also has balanced XLR's on the rear as well.
james
spinner
« Reply #4 on: 28 Apr 2012, 06:24 pm »
 But why bother? :? Does this have to do with better noise rejection?
« Reply #5 on: 28 Apr 2012, 06:30 pm »
Yes (common mode noise rejection) and each channel is totally independent as well.  Also there is some extra DB's of gain (12) if you need it with difficult to drive phones.
james
spinner
« Reply #6 on: 28 Apr 2012, 06:37 pm »
  I have the AKG 701's. All I need to do is get the plug changed (assuming there's enough wires) to realize this effect?. Thanks James for  your input.... :thumb:
« Reply #7 on: 28 Apr 2012, 06:51 pm »
Correct.
James
mkaiser
« Reply #8 on: 28 Apr 2012, 08:20 pm »
Hi Mark,
/quote]
Okay, thanks for the update James. Yes, i currently have the Cardas XLR headphone cable and have had great results when compared to the 1/4 inch plug designs.
Mark
