0 Members and 1 Guest are viewing this topic. Read 70142 times.
I need amp, HT preamp and maybe stereo preamp. I want to run stereo subs. (Probably Salk Rythmiks). It seems many of the pre-pro units don't do that. I plan to set up a 5.2 surround room, and was thinking the music config would be 2.2.What is your recommendation for a processor? All the name brand processors (like cary, arcam, monitor, etc) seem to only do mono subs, which I don't want. I can't really afford to jump up to the classe, which leaves me really wondering.Is it possible, or advisable to run a dedicated 2-channel pre-amp inline with the HT pre-amp? If so, which goes first?
I think "the best of both worlds in a single system" is unrealistic. It's about compromises you are willing to make to to achieve a good balance given a certain budget.
I listened to Janis Joplin singing "Little Girl Blue" and was brought to tears - literally.
The OP expressed a desire to integrate a dedicated 2 channel pre-amp into his HT system, which is relatively straightforward and many would consider this a worthwhile upgrade over an AVR as pre-pro. The bass management for two subs is really the tricky part, but there are solutions for that as well.
My only problem with this integration is that its such a hassle to integrate a 2 channel scenario with subs involved.
What was the source of that audio, CD?
It is on the Kozmic Blues album (I Got Dem Ol' Kozmic Blues Again Mama!) as well as some compilations.
I was wondering what the source was (i.e. CD, SACD, Vinyl, etc). This can have a huge bearing on the results, especially when a savvy salesman tilts the field in his favor by picking something that sounds exceptionally good. I have the Big Brother and the Holding Company CD but would never even think of using it to demo as it sounds pretty muddy on any system.
I am very interested to find out what amplifiers everyone is using to power their Salks!What speakers do you have?What amp/pre-amp for stereo? What about surround?Cheers!
My only problem with this integration is that its such a hassle to integrate a 2 channel scenario with subs involved. If your running a 2 channel HT bypass with full range speakers and no subs its not nearly as difficult. Bass Management with subs with your 2 channel bypass is alot of work... I'm not saying its impossible, as I did it, but all the monkeying around to me just isn't worth it... in the end it all boiled down to simplicity..... Obviously to each their own and I commend anyone for working towards perfection...
Subwoofers are very much associated with home theaters. Any pure-play 2 channel audio system would must borrow multi-channel DNA to "do it all". This is why I chose full-range floorstanding speakers
