0 Members and 1 Guest are viewing this topic. Read 6742 times.
I am looking for sound quality above all, but getting rid of wireless streaming would be nice also!
There can sometimes be issues with the Touch and external drives. Apparently it depends on the drive. Some work well with the Touch, some don't. I have an Iomega USB drive that works fine with it.
... the other thing I have seen mentioned on the circles is the relative lack of power and memory in the SB Touch being an issue re slow or interrupted playback of big files, but it sounds like you are not having that problem so that's promising.Am wondering if and when a new SB Touch is arriving. Seems like a while since they released it.
I've owned the Touch since they were first released 2 years ago. I've never had an issue of either slow response or interrupted playback, and I have a large collection that includes lengthy single classical tracks. The key is it is strongly recommended the Touch be used with an external server. (I just recently retired my old server and replaced it with a Vortexbox.) You should avoid using the Touch with only an external USB drive. The external drive direct to the Touch works for some but not everyone.
I would STRONGLY suggest you to stick with what you have - since you have been happy with the sound - yes better sound can be had - if you know nothing about Macs it may or may not be a lot of fun re-starting again - tweaking, upgrading, debating etc.
