SOLD: Lynx L22 high end professional balanced sound card
0 Members and 1 Guest are viewing this topic. Read 1221 times.
WerTicus
SOLD FOR $250... someone got a bargain!
As many of you know this sound card is still regarded as the best PCI computer sound card available.
I has served me very well but with my first child on the way I am simplifying my stereo setup.
Our very own Hantra has put up a good write up on the card here:
http://www.audiocircle.com/index.php?topic=15994.0
This sound card can keep up with the big boys.  Actually this card IS the big boy ;-)
  • 200kHz sample rate / 100kHz analog bandwidth (Supported with all drivers)
  • Two 24-bit balanced analog inputs and outputs
  • +4dBu or -10dBV line levels selectable per channel pair
  • 24-bit AES3 or S/PDIF I/O with full status and subcode support
  • Sample rate conversion on digital input
  • Non-audio digital I/O support for Dolby Digital® and HDCD
  • 32-channel / 32-bit digital mixer with 16 sub outputs
  • Multiple dither algorithms per channel
  • Word, 256 Word, 13.5MHz or 27MHz clock sync
  • Extremely low-jitter tunable sample clock generator
  • Dedicated clock frequency diagnostic hardware
  • Multiple-board audio data routing and sync
  • Two LStream™ ports support 8 additional I/O channels each
  • Compatible with LStream modules for ADAT and AES/EBU standards
  • Zero-wait state, 16-channel, scatter-gather DMA engine
  • Windows XP/Vista/7 in 32-bit and 64-bit: ASIO 2.0, WDM, DirectSound. Legacy Windows drivers available
  • Macintosh OSX: CoreAudio (10.5 & 10.6). Legacy drivers available
  • RoHS Compliant
  • Optional LStream Expansion Module LS-ADAT: provides sixteen-channel 24-bit ADAT optical I/O (Internal)
  • Optional LStream Expansion Module LS-AES: provides eight-channel 24-bit/96kHz AES/EBU or S/PDIF digital I/O (Internal)
I dont really know what it is worth but they are still $700 new on B+H So I am putting it up for auction on ebay starting at the low low price of 99c ;-)
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=251041300361
Shipping to AU, USA, CAN, NZ, UK. (so it should show up in a search on your local ebay site if your from one of those countries.)
« Last Edit: 22 Apr 2012, 07:49 am by WerTicus »
