A pair of 7Bs or one 14B?
0 Members and 1 Guest are viewing this topic. Read 13528 times.
electricbear
« on: 10 Apr 2012, 01:18 pm »
My appologies if this has previously been covered elsewhere. What would the differences be other than $$$ between doing a pair of 7B-SST2 or one 14B-SST2? Speakers most probably will be B&W 802Ds. Thanks for your input.
Sasha
Re: A pair of 7Bs or one 14B?
« Reply #1 on: 10 Apr 2012, 02:40 pm »
I did comparison between 7B SST and 14B SST driving PMC IB2S, 7B was noticeably better, my educated guess was that 7B outperformed 14B mostly due to its larger PSU.
For what it is worth I consider 7B SST among the best performing and reasonably priced monoblocks on the market, they are much more capable of driving difficult loads than their lower powered siblings.
SHV
« Reply #2 on: 10 Apr 2012, 03:33 pm »
The 7B's will be easier to move.  I have 7Bs and a 6B which is about the same size and weight as a 14B and it's a back breaker. :>)
Vipers
« Reply #3 on: 10 Apr 2012, 04:06 pm »
I agree with all the above and as a 7B SST2 user driving a pair of PMC MB2i's I couldn't be happier with their performance.
Obviously the big advantage of the 7B's over a 14B is that you can put one next to each speaker hence keeping the speaker cable as short as possible which in theory all helps overall performance.
electricbear
« Reply #4 on: 10 Apr 2012, 04:10 pm »
Thank you all for your responses. You've affirmed what I was already thinking.
spinner
« Reply #5 on: 10 Apr 2012, 06:47 pm »
 I assume that, all things being equal, the 7Bs would present a more forward dynamic presentation than the 14B ! :scratch:
werd
« Reply #6 on: 10 Apr 2012, 06:50 pm »
Go with the 14B its way nicer.....  :D
spinner
« Reply #7 on: 10 Apr 2012, 06:53 pm »
  What's "nicer" ? :P
drummermitchell
« Reply #8 on: 10 Apr 2012, 10:40 pm »
MONOBLOCKS=MANFOOD :slap:.
medium jim
« Reply #9 on: 10 Apr 2012, 10:59 pm »
Mono blocks give you better separation, which means better soundstage...go with a pair of 7b's.
Jim
spinner
« Reply #10 on: 11 Apr 2012, 01:50 am »
 That makes sense. :thumb:
budt
« Reply #11 on: 11 Apr 2012, 02:49 am »
  I am very happy with my pair of bryston 7b sst2 driving B&W 800 diamonds.
werd
« Reply #12 on: 11 Apr 2012, 03:21 am »
Jim
They are both mono blocks. The only difference is the 14b is one piece.
tim92gts
« Reply #13 on: 11 Apr 2012, 07:45 am »
Another vote for amps close to speakers here, when you upgrade to the 800s you can then just get a pair of crossovers and two more 7Bs!
Wallacefl
« Reply #14 on: 11 Apr 2012, 11:14 am »
...cannot vouch for the type 2 but I compared 7BSST V. !4BSSt...no difference..I purchased the 14.
tim92gts
« Reply #15 on: 11 Apr 2012, 01:58 pm »
That's good news, i couldn't do a representative side by side comparison so this thread got me wondering if i should have gone for 7 rather than 14B last year, the whiole power supply difference wasn't publicised much then.
Tim
medium jim
« Reply #16 on: 11 Apr 2012, 03:07 pm »
Different Power Supplies...
vegasdave
« Reply #17 on: 12 Apr 2012, 07:36 pm »
I'm going for the 28s! But yeah, I would choose the 7Bs.
redbook
  • the music is the blood...........
« Reply #18 on: 13 Apr 2012, 02:19 am »
  No disrespect but aren't mono blocks supposed to be on separate chassis?  :scratch:
medium jim
« Reply #19 on: 13 Apr 2012, 02:39 am »
Redbook, Bryston confuses the issue by saying the 14b is basically two 7b's under one hood.  However, only one power supply? Thusly, not true monoblocks.
Jim
