0 Members and 1 Guest are viewing this topic. Read 50215 times.
@paul: is everything hooked up like before? check all the connections.
Problem solved yesterday after messaging with Dan Wright of Modwright...seems that there is a molex connector on the rectifier board that can come loose, mine did. Simple to reconnect and voila...music again!
I ordered both Burson and Dexa's - complete set of each. Almost $600.
I ordered the same compete set. I listened to the Dexas for 2 days and now I'm spending 2 days with the Burson. The difference with the original EE DAC plus op amps and with both these new op-amps is day and night, massive improvement, not slight...HUGE. I will post more impressions, once I've spent more time with them.
Glad that your Dac is fixed.Is Dan doing mods on the EE Dac?
I just ordered a Psvane tube to try in place of the Amperex i'm currently using.
Please let me know your impressions of the Psvane tube.thanksTOm
I've had the Dexas in for a week or two and while I'll say they sound better than the stock opamps, I wouldn't characterize the improvement as huge. Inserting an Audio Art Statement I power cord on my amp made a bigger change and the amp already had a decent power cord on it. YMMV...
Dac+, running the SS out, with tube pulled.
Can't wait for your impressions of both. Specifically, a comparison of the two.
Certainly our systems, personal preferences, grading scale for changes, etc. play a role in determining whether we as individuals call something massive or subtle. In my system, pulling the tube out wrought a larger change than swapping opamps. The DAC sounds better with the Dexas, no doubt, but to me, it's not on the order of changing a component or something like that.As another data point, the rest of the system is an Aaron No.1.a integrated amp, driving Harbeth Compact 7ES-3 speakers, interconnects and power cables are Audio Art SE or Statement versions, and power conditioning is supplied by a Shunyata Hydra.
Been there done that. I am not surprised why am not excited about them. LOL...
