0 Members and 1 Guest are viewing this topic. Read 50219 times.
Picking up from the other thread...I'm currently breaking in a 2604/827 combo, and I also own LME49990 duals. It seems for me, I can't find anything that works better than the OEM opamps. I also seem to prefer the tube output with a Psvane tube.For me, I lose too much dimensionality with the SS output, no matter what opamps I try. I admit the 2604/827 combo might be the best SS output I've heard, but I hear a hint of distortion from the 2604's, and combined with my Psvane tube, the lower midrange/upper bass gets sort of thick sounding and really detracts from any sense of realism from the sound. The 2604's have definitely changed as time has gone on. I think I have around 100 hours on them now, but I didn't get to listen today. I just installed the 827's for the SS output yesterday. They now have just over 24 hours on them. I'm hoping to listen tomorrow evening for bit to find out how things have progressed. The LME49990 duals were incredible when I first installed them some months ago, but they became a bit thin for my setup. Not that they don't do some good things, but my setup can't afford the loss of any weight. However, before I give up on all of this, I plan to try the LME49990 duals with the 827. For the record, all SS output listening has been sans tube. And just so you guys don't think this is only my opinion, I just had a fellow AC'er over this past Saturday to objectively listen to all of this. He too found the OEM opamps with the Psvane tube to easily sound the best for my setup. It was very important to me to get this figured out with someone else as I have a big GTG coming up on the 14th. I really need my setup performing its best.
Picking up from the other thread...It seems for me, I can't find anything that works better than the OEM opamps.
Still haven't heard a tube that wasn't too indistinct and vague in the bass relative to upgraded op-amp SS section. Just too much info glossed over w/ the tube, though I can see how that might be a good thing.
I'm at a loss as to why the op amp swapping continues to be such a hot topic when, to many, the improvements over the stock amps seem negligable. I tried going tubeless but preferred a Psvane with tube output. But the differences were very minor overall in my system. On the other hand, I just replaced my tube preamp with a DYI Dodd buffer and the sound improvement was at least 30 times greater than the improvements I heard swapping things out in my Dac+. If you are looking to improve your system, I just think there are much bigger gains to be realized away from the Dac and for not much more cash.
Wonder how did you mange to measure so precisely (30 times!!!), as an absolute number, sonic quality improvement which involves so many characteristics, for the most, of a totally subjective nature. In any event, and I don't mean to be sarcastic or disrespectful, assuming that you really have the ears to quantify so objectively without any sort of instrument(s) and a credible/accurate measuring scale as a defined benchmark--and given that you are using a MiniMax plus not the original with those actually absurd output impedance specs, as wilsynet points it out (which is likely to not only introduce source signal gain losses but to also alter frequency response performance when combined with the LCR circuit characteristcs of the interconnects being used and the input impedance of preamp/amp)--the only logical explanation (to me) of such observed large improvement from inserting an inexpensive (never mind good quality) tube buffer and removing your tube preamp is that there most be something wrong with your tube preamp (unless it is a low quality one to begin with).munosmario
In prior posts the gentlemen stated that he had a Eastern Electric MiniMax preamplifier which is not a bad little preamp at all.sound quality is a subjective thing based on personal preferences and if he feels he had a dramatic improvement switching to the Dodd Buffer good for him
Levi:My last post on the prior thread wasn't a review of the Dexas - merely a first impression. I plan to run them in for a couple of weeks before making any significant judgments.
