0 Members and 1 Guest are viewing this topic. Read 50281 times.
Cool, have they reached the 100+ hours?
All I can say for certain is that I don't find myself thinking about the sound, I'm just listening to the music. Hopefully that means things are sounding right.
I know this is an old thread but I wanted to post and say that I just had the Dexa op amps installed in my original mini max DAC (not the + model) and the improvement in sound is not slight. Much improved base and much better mids and highs. Thanks Bill at Morningstar for a quick turnaround. If you have this DAC it is very well worth the upgrade costDavid
LeviI have yet to try the tube output with the new Dexa discrete op amps but will do so. I replaced the single and the dual, so both SS and tubeDavid
I also am now using Dexa's throughout for about a year now, but since I had mine fitted with with Vcaps on the output stage and also the power supply , thanks to Bill Baker over at Response Audio, only the tube stage is used otherwise it would bypass the fantastic Vcaps. Had to raise the top cover about an inch to fit in the caps though. Bill did a great job on it though. Currently using a pinch waist D getter version E80CC tube.Dynamics out the ying yang.
ps. why is there so little press on this great little dac? Seems like it was really popular a year or so ago.
Yes, the DEXA's, to me, were head and shoulds above the Bursons.
