Do I need a Squeezebox Touch? IDGI (yet)
0 Members and 1 Guest are viewing this topic. Read 1075 times.
flyingelephant
« on: 3 Apr 2012, 05:36 am »
I've become fascinated with the idea of a Squeezebox Touch to add to my multi-zone Mac Music server (using several Arport Expresses, <$350 Toslink DACS and powered speakers for the satellite areas, and a Rega Dac, Mac Mini, tube amp and Joseph Audio Pulsars for the main system. iTunes and Remote are my main software items. Getting ready to play with Pure Music and/or AudioNirvana)
So - here at Audio Circle, many seem to like the SB Touch a lot, especially with the Digital Mod from Bolder Cable (costs more than the SB Touch) and the Bolder linear power supply with Bybee Music Rail (add another $800.) That makes it an almost $1500 unit (with apparently amazing sound quality at that point.)
I saw the positive review Chris did over at Computeraudiophile a while back - so I'm intrigued. He put the SB Touch on his exclusive C.A.S.H list - sort of of Hall of Fame for equipment and software.
At the same time, I can't quite see what I'm going to get by having a Squeezebox in my life, as opposed to the Airport Expresses and my main system. I know it implements internet radio pretty well, and handles FLAC files. I am using 16/44.1 aiff files, for the most part. I do like Pandora and SiriusXM.
So - Squeezebox fans - what's the big deal? Or am I just not getting something? Thanks!
wilbert-vanbakel
  • Photoshopped Smile
    • On Facebook
Re: Do I need a Squeezebox Touch? IDGI (yet)
« Reply #1 on: 4 Apr 2012, 01:25 am »
Sounds like you are quite happy with your setup and yes, other grass is always greener.
At http://www.mysqueezebox.com/index/Home you can see which apps are available for the squeezebox server (it's renamed to Logitech Media Server, recently), you are able to install the server on your Mac Mini and there is also a player available.
Without spending money (but you will spend some time on it) you are able to explore the options.
I have Logitech Media Server running on a low power system and this system also handles the audio output. You probably will be able to accomplish the same with your Mac Mini.
You are not missing anything, it's perfectly okay to be happy with iPhone while being 'intrigued' with articles about Android.
