Bryston B135 SST/2
0 Members and 1 Guest are viewing this topic. Read 72564 times.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston B135 SST/2
« Reply #160 on: 4 Sep 2017, 10:42 am »
Hi James
When using the B135 sst2 as a preamp, is it possible to turn off the poweramp section?
Sam
Hi Sam
No sorry that is not possible - it would be using very little power though as it is sitting at idle.
james
samye83
« Reply #161 on: 4 Sep 2017, 11:32 am »
Thanks for the answear :)
I have measured the power usage, and it was about 65-70w at idle. When I switch the buttons at the rear panel to separate, would the idle state consumption go further down?
« Reply #162 on: 4 Sep 2017, 12:43 pm »
That sounds right.
james
srb
« Reply #163 on: 4 Sep 2017, 12:50 pm »
Looking at the specs for the cubed series -
B135³ integrated amp listed at ≤ 70W at idle
2.5B³ power amp listed at ≤ 40W at idle
- I would think that the power amp section may be consuming ~ 40W at idle above what would be the idle power consumption of the stand-alone BP17³ preamplifier? (specs not yet available for BP17³ preamplifier)
