0 Members and 1 Guest are viewing this topic. Read 15082 times.
I am not as concerned with trapping the bass towards the floor. The room is carpeted and it seems to do quite well down low. I can clap my hands at floor level and there is no real slap echo. As I raise the height of my hands an continue to clap the echo becomes worse. It was recommended that I treat my walls higher up as opposed to down low.
Have you tried a set up using the long wall on the right, so your chair is on the left? Is that possibe?If so, do it with all the panels removed from the room at first and try and get the best bass. Then introduce your bass traps. Your speaker manufacturer should be able to offer advice about speaker placement. He should also be able to tell you what the spread of the mids and high frequencies will be. That way you'll have an idea of how they will be reflected.Another possibility is to remove the side panels so you DO get side wall reflections. I found this added a bit of life to my room.I also found that, with a carpet and my speakers around 10' from my chair, ceiling absorbers made no difference. My chair has a high back so rear wall absorbers also do nothing.How do you know what bass frequencies, and other ones, are troubling you?As well as acoustic foam, I used a digital equaliser to solve some problems (a Behringer DEQ2496). Complicated to use but I like the results.
jlafrenz,My room is almost the exact same size as yours 12.6 x 15.6 x 7.8Getting the bass clean, tight and coherent was the hardest part for me. Still a work in progress...Since you say your room is lacking dynamics I am curious. Can you please list the config of your system?Thanks
Take some acoustic measurements, and post them up here so we can see what's going on. Without measurements you are just shooting in the dark!
Nice system sirI know you mentioned time to stop investing but have you ever tried to roll the tubes in the pre-amp section?
You could make some room measurements with the Behringer using its Real Time Analyser with it's own Pink Noise source. You will however need a microphone, microphone stand and suitable cable.Some will no doubt argue it's not that accurate but it should give some good clues as to what is going on.If you need any help on this just ask!
How does one measure dynamics? Impulse response? Waterfalls? RT60?
