Dumb Logitech Touch question
0 Members and 1 Guest are viewing this topic. Read 1187 times.
mca
« on: 22 Mar 2012, 10:10 pm »
This may be a dumb question, but I can't seem to find the answer anywhere. If I choose to run my Touch wired, do I still hook it to the router or directly to the computer  :scratch:
jimsmy
Re: Dumb Logitech Touch question
« Reply #1 on: 22 Mar 2012, 10:14 pm »
Connect to the router.
Noseyears
  • SS-Audio
    • Supreme Sound Audio
« Reply #2 on: 22 Mar 2012, 10:38 pm »
Its simple, just connect 1 cable computer > router.
and another cable router > Squeezebox Touch.
Big Red Machine
« Reply #3 on: 22 Mar 2012, 10:42 pm »
Yeah, router.  My Touch and desktop are on the opposite side of the room from the low voltage panel for the house.  I run 2 lines to the rack, one for the Touch ad one for the desktop.  The desktop finds the Touch via the router connection and if using a computer screen with the desktop to run the Logitech Media Server then you are all set to use the computer to play tunes and surf at the same time.
