0 Members and 1 Guest are viewing this topic. Read 6313 times.
I can't say that I have tried this, but it seems to me that Rythmik's suggestion may work. This wouldn't be practical for most folks because most people have 2 or more sources (turntables, CD, Streamer, etc, etc) so it would require swapping cables every time you change sources.One problem I could see would be volume control. I think you would need to control the volume at the CD player instead of the integrated amp in order to get the sub volume in balance. If it is just a straight line level output from the CDP, the sub would be at a fixed volume and have no way to adjust volume when you change volume on the intregrated amp. If your CD player can do that, you should be fineGood luck. I look forward to see how it works out for you.Tom
And I've run the 80hz X/O on sub (ie overlapping with ST's) listening to reggae and electronica.. sounded pretty good with all that bass, but probably not the best way for other types of music!
you could get an outboard active x-over; set the rhythmik's x-over at its highest setting, then set the active x-over at 50-80hz, low-pass to the sub amp, hi-pass to the salk's amp. and use the active x-over to balance the levels between the sub and the salk's. i think you will also find a quality active x-over will be much more transparent than that in the sub's amp...doug s.
While this is likely true, you can't use an outboard crossover with an integrated amp with that sub. OP: The best solution for you is to run your Salk's full-range and let the sub over lap. There is really no harm in that as long as you have the sub and mains in phase at the overlap point. That Rythmik sub is very musical, and should blend very well with your Salk's. You may not need a low-pass of 80Hz with the Salk's, but you won't know that unless you measure the in-room frequency response. 80Hz is a good place to start though. You are likely experiencing room modes from the sub. This will make some genres of music have tremendous bass, and others not enough. It's my opinion that any sub used for music should be EQ'd for the room. If you can't do that, then you need to find the best location for the sub where it has the flattest overall response. You can primitively do this with a db meter and test tones.The easiest primitive way I know to get the sub in phase with your mains is to set the sub's low pass at 80Hz, play a test tone of 70-80Hz, and simply adjust the phase to get the most output at that frequency. That will show the sub and mains are in phase. Then adjust the sub's level to taste if you must.
bigfishk mentioned his integrated has preamp outs; i assumed it would also have main inputs. if it does, then the hi-pass outs from the active x-over would go to the main inputs of the integrated. if the integrated doesn't have main inputs; you're correct; it won't work. ime, it is good to actively cross mains when using subs, because both the amp and the speakers perform better when relieved of having to do low-bass duties.regarding room node issues, the easiest way to deal w/that is to run two (or more) subs, to even out standing waves. it is really difficult to get smooth bass in a room over a wide area, w/a single sub. and, my experience has also been that, regardless of what is said about (lack of) directionality of low frequencies, soundstaging is better w/a pair of stereo subs.ymmv,doug s.
The sub has Parametric EQ but I have no bloody clue how to do that, despite reading some info on the website. .but maybe this is the route to deal with room nodes?
...I just started to do what Doug suggested- overlapping ST's and sub, X/O at 80hz...
If I were the OP, I'd try using those test tones and a db meter to plot the bass response as best I could. Then use the sub's parametric EQ to knock down the largest peak between 30 and 80Hz, and just listen like that for a while. Then I'd try the PE filters in the tape loop. You also don't need to go -24db on them either. My -12db slope at 70Hz works great. They remove a tremendous amount of bass from my mains. Certainly enough for things to sound absolutely wonderful.
