Crossover advice re song towers and sub
0 Members and 1 Guest are viewing this topic. Read 6310 times.
Bigfishhk
Re: Crossover advice re song towers and sub
« Reply #20 on: 9 Mar 2012, 10:34 pm »
Gzerro,
So I did the test 20-80hz.   the total range 70db-85db
would definitely appreciate intepretation of the results and consequent advice on PEQ settings if needed.
At the risk of looking like an idiot, thee measurements taken with sub alone, with mains disconnected right?
tx
TOm
« Last Edit: 9 Mar 2012, 11:39 pm by Bigfishhk »
Gzerro
« Reply #21 on: 10 Mar 2012, 12:06 am »
Good job! Yes it is correct to measure the sub by itself.
First of all you have a really good room! +-6db is fantastic. I wish mine was that good.
A small adjustment at 40Hz wouldn't hurt. Gain -5, width around 10 o'clock on the dial.
Here is the link on the Rythmik guide to the PEQ settings:
http://www.rythmikaudio.com/amplifier_controls.html
If I were you I would just set my x-over around 40-50Hz to slip in under your STs and enjoy.
Take care,
Tom
Bigfishhk
« Reply #22 on: 10 Mar 2012, 01:31 am »
G,
Didn,t know I had a good room! Good to know. Time to listen a bit more and fiddle with knobs less!
Having said that I willl give your settings a whirl.. In gratitude I,d like to send you a cd compilation I am making with a bassy emphasis. Eclectic music from electronica to Lou reed.
For that matter also Tj hub and Doug who patiently answered, would you like a cd comp?
If you would like the cd, pls send me your address.
[email protected]
Bigfishhk
« Reply #23 on: 10 Mar 2012, 06:16 pm »
Finally the sound is coming together.. More balanced than before, and good, not overblown bass impact.. Crossing over at 50hz, with the peq adjustments as suggested. The peq adjustments definitely helping.
Can relax an d enjoy the music without any fussing with dials for a bit!
Tom
Gzerro
« Reply #24 on: 11 Mar 2012, 03:04 am »
Congrats! :dance:
I love it when a plan comes together!
Also thank your for the offer of the comp - I will send you my address.
Take care,
Tom
doug s.
  • makin' music
« Reply #25 on: 11 Mar 2012, 03:49 am »
Congrats! :dance:
Take care,
Tom
+1 - on both your results, and the compilation cd!   :thumb:
doug s.
