0 Members and 1 Guest are viewing this topic. Read 13537 times.
I had to adjust micro inches to get a perfect left/right balance. But once I did, it gets rid of that Maggie head in a vise feeling.
Thats called a pair of headphones for those of you who have never seen a set before. It works better if you set right in the middle however.Scotty
Now, if you want a *real* blast, try turning them so they're edge-on to you, e.g., in a "V" with you at the point. If it works (it does in some rooms, not others) you'll be amazed at and blown away by what happens.
I tried it as well. It's an interesting presentation.I think much depends upon the recordings used....how they were miked, whether ambient information is contained, etc, etc.The typical contemporary horrible studio recordings that are a close-miked pan-potted mess will probably not demonstrate the capabilities of this type of configuration.I have a few binaural recordings of a symphony orchestra. Those sound terrific.Cheers,Dave.
While I don't have these speakers, I suspect that what you've done is moved a good part of the treble energy to the reverberant field, hence no "head in a vice."I'd be interested to hear how it fares with more extended listening
Funny, I was thinking of trying that very thing out. The author of the original post adjusted his from directly paralleled to slightly tilted toward the front wall. I ended up with (a guesstimate) 1 or 2 degrees tilted, almost by accident, but it sounded better. So I wondered what the "on edge" sound might be and if it mattered much which edge, facing the front or rear walls.
I'd put the front (diaphragm side) of the speaker facing out. When you do this, you actually don't hear direct sound from the speaker anymore, since you're in the dipole null. Instead, the first arrival comes from a reflected "virtual speaker" that's beyond the physical wall. The second arrival comes from the front wall. This has the effect of making your room larger acoustically, and also increases the lateral spread to maybe 150 degrees without a hole in the middle. It's pretty amazing when it works, the closest I've experienced to being in a real acoustical space. And it seems to work about half the time, depending, I think, on room symmetry.
Seriously near field is a bit spooky too. I swear that I keep hearing sounds coming from behind me.
