0 Members and 1 Guest are viewing this topic. Read 14412 times.
It uses 4 individual wires that are then twisted together. The thing is that I need to make one run (to a sub) that is really long - 100' or so. The other runs will be between 15' -25'.
These are available in 100' lengths.... http://www.6moons.com/audioreviews/whitelightning/moonshine.htmlI used them in my system. Love 'em.Bob
I am really just trying to find a nice way to keep these strands together - you know something that looks good.
Bob,I use these currently but only in the white and only have only seen them at 40'. Can you show me where you can get this at 100'? AND in black? They black will be key for hiding the wires.
Stretch out all four wires and clamp them in a vice at one end. Head to the other end chuck all four wires in your electric drill and then go to it. (Make sure you comb them beforehand or you'll have an odd twist somewhere.)When you stop "drilling" and before you turn loose of the wires in the chuck give the whole thing a hard jerk. This tends to "set" the wires in the twist. Remove from vice and drill and clip off the portions that were squeezed hard.If you want to braid.....it's going to be a much more tedious process. Cheers,Dave.
The drill chuck turns, the wires twist one over the other. The problem is each individual wire twists as the chuck turns. Within a surprisingly quick number of turns the torque stored in the four twisted wires results in one or both of the following (the thicker the AWG the quicker the torque increases):Absence of hand/finger/wrist strength to continue holding the drill and twisting the cableAbsence of drill torque required to turn the cables As the euphemism goes, been there/done that.Even if one was somehow able to find the hand and drill strength to turn 100' (impossible), and then strong enough tape to bind the wires at the vice end before removing from the vice, the combined torque in the wires would equal a pipe and never be bent or turned to any shape except straight. Have you tried what you describe? If yes, and it worked, I am surely missing something, but I doubt it.
Right after Six Moon came out with this, and the "big rave and reviews" was going on, I bought several of the 40' lengths for my several channels of full active system. At the time, they had white, tan, and dark green in three different lengths. I can't recall now, but I think they were something like a short 20'(?) the popular 40' and something very long. If memory serves, it was the typical 100' extension cord distance. But they never had black that I've ever saw.But as was mentioned above, some black techflex would help the color issue. A decent cable with a good appearance, and very little work and cost. An equation that's hard to beat.Bob
