0 Members and 1 Guest are viewing this topic. Read 89920 times.
anyone know why the Selah are $1000 for an upgraded veneer? I don't even think the Salk floorstanders are that much with double the surface area and I would imagine their work is probably considered the best of the three also.
well, it's a legitimate question and I'm not criticizing Selah. I'm seriously considering the Tempesta, but I don't want a standard finish and the only thing stopping me is the 30% addition to the cost for an upgrade.
Hard to say Whether the tempesta are better or the cirrus. Both have their qualities. But i gotta say i love the looks of the cirrus. Also, if there were standard in measuring sensitivity, the cirrus has some advantage being 3 db more sensitive. The cirrus also dig deeper within its -3db. The woofer from AT is made of polypropylen , not sure how they compared to scanspeak aluminum cone in terms of detail.
Does it matter if it's 30% more if the final price still represents good value?Where the standard veneers are applied at a lower cost geographic location, a custom veneer may have the additional cost of stripping the cabinet of its original veneer and then applying the custom veneer. So it's sort of double work.
of course it does, unless you don't mind paying 30% more just because it is still a decent price.I guess I can understand the double work argument, but if it costs that much to strip the stock veneer it seems like it would be a LOT cheaper to just build a new enclosure.
Just wondering about your Zu Soul Superfly speakers. Have you, or are you planning on moving on from this model?
Since you've already purchased the Selah's, I won't go on about Harbeth but I was going to advise that you not discount the line due to the negative experience with that one dealer.
Why swap out the PMC AML-1's with any of these? Seems like a sideways step at best to me.
Maybe Selah should have priced the standard veneer models at 15% more just so you could feel good about paying less incremental dollars for the custom veneer. But that wouldn't represent good value to the customers who don't want a custom veneer.Would it make you feel better if everyone paid more so that you could incrementally pay less, even though you're still paying the same amount in absolute dollars?
i am surprised this is surprising to anyone.
I had no idea. Those PMC AML1 speakers were $8,500 new, and have integrated Bryston amplifier modules.I would imagine that yes, it would likely be a sideways move. Really a matter of taste rather than better or worse in absolute, irrefutable terms.
if you get a special finish on the tempesta, you are paying for the material cost of the stock finish
now you're just being silly. my question of why a Selah veneer is so much more expensive than similar vendors is the question.
You have obviously NEVER built an enclosure from scratch. I have. 30% is faaaaaarrrrrr less that I would charge to build it. And stripping the existing veneer is NOT a good option. Or, you could save ALL that money by building the cabinets yourself and you can see for yourself what exactly is involved. Seems simple and easy. It's not.
