0 Members and 1 Guest are viewing this topic. Read 23830 times.
Hey guys, this is the solid state circle. Tubes need not apply.
maybe the thread should be moved to another circle, if making suggestions requested by the o.p. are considered inappropriate? ymmv,doug s.
Hi JW, I'm sorry to disappoint. If you need a built in phono preamp, SAS unfortunately does not have a commercial model. Steve said he designed a somewhat exotic stand-alone tubed phono preamp with regulated power supplies, etc., but he chose not to offer it because it would have been too expensive to offer it as a commercial product. Either way, I believe the design is too large to offer as a built in option on a standard SAS preamp. Someday I'd like to have a great vinyl setup but it will have to wait a bit. Roscoeii has a really nice sounding vinyl setup and an impressive collection of albums (by my standard at least). Maybe I'm old school but there is something special about listening to a great recording on vinyl. Your system looks amazing, and you have owned some truly exotic gear over the years. I wish I lived close enough to hear it in person! Cheers,Jack
I have a tube pre that I'm happy with so a stand alone phono pre is what I'm after. Oh well, thought I'd try. I do wonder what SAS would sell it for though.
i have always found s/s fono stages to be wery nice w/tubed line stages...doug s.
Really? What do you suggest then in the SS realm?
If a passive pre-amp works for you, that's great. But the pre-amp's primary role is not gain. Attenuation would be an obvious attribute, but I'd claim it's primarily impedance matching. Here are some of Nelson Pass' thoughts on the subject:http://www.enjoythemusic.com/diy/0708/first_watt_b1_preamplifier.htm
(1) not only do i disagree with you, you disagree w/yourself. why not run a passive fono stage? (2) what does "zero distortion" mean,(3)...for my ears, nothing does better than a top notch tube preamp(4)... the ears know best.
(1) i know why you use an active fono stage - it sounds better than passive. (2) i know what zero distortion means(3) the point i was making is that zero distortion to the recording does not, in and of itself,
...Good luck. Tubes are obsolete.
It's like saying horns are obsolete...
