Differences between 2B-SST2 and 3B-SST2?
0 Members and 1 Guest are viewing this topic. Read 1913 times.
MoonUnit
« on: 22 Feb 2012, 05:06 am »
I'm just curious what the differences are between the 2B-SST2 and 3B-SST2 other than the 50 watt difference in power? From what I can tell from comparing the spec sheets, almost all the specs are the same, but there is a substantial increase in heat dissipation of the 3B-SST2. Is that related to a heavier biasing towards class A or something like that?
  • The Demo is Everything!
    • http://www.bryston.com
Re: Differences between 2B-SST2 and 3B-SST2?
« Reply #1 on: 22 Feb 2012, 10:10 am »
Hi
The 3B has 4 output transistors per channel (2B has 2) and a much larger power supply so the 3B can deliver much more power to lower impedances than the 2B.
James
MoonUnit
« Reply #2 on: 23 Feb 2012, 02:51 am »
Thanks... that's just the information I was looking for. My speakers are 4 ohm so it's probably worthwhile to consider the 3B.
SoundGame
« Reply #3 on: 23 Feb 2012, 01:35 pm »
Or the 4B for about $700 more... :wink:
JBLMVBC
« Reply #4 on: 24 Feb 2012, 05:04 pm »
The 2B is a wonderful beast for multiamplified systems, for driving medium and highs units, refined and yet dynamic.
Hi
James
hawkeye99
« Reply #5 on: 26 Feb 2012, 12:24 pm »
Anybody have experience with the 2B SST2 and Totem Model 1 Signatures (4 ohms)?
SoundGame
« Reply #6 on: 26 Feb 2012, 04:52 pm »
The Model 1 will run with the 2B-SST2 but not to it's full potential.  You will get better performance out of the 3B-SST2 or higher.  Totems tend to show better with more power.  That said, if cash strapped, a 2B-SST2 will likely do the job.
