Will Squeezebox Touch play "website streams"?
0 Members and 1 Guest are viewing this topic. Read 2452 times.
Chromisdesigns
  • Darla, our beach cat, contemplating the sea
    • Fine-gemstones.com
« on: 18 Feb 2012, 08:52 pm »
I am wondering if I can use my SB Touch to listen to tomorrow's Warren Hellman memorial concert, being streamed online at www.strictlybluegrass.com?
I use it frequently for internet radio stations, but can I just point it at the appropriate link from the above website to hear the concert?
Bob
Chromisdesigns
Re: Will Squeezebox Touch play "website streams"?
« Reply #1 on: 19 Feb 2012, 08:59 pm »
Turns out you can't do that.  No way to enter a URL that I could find, so can't even tell if it would work with a specific streaming tech.  All you can do is search internet radio stations, and I couldn't find one that was carrying the simulcast.
Oh, well -- guess I'll just have to spend the afternoon in front of the computer, with my Nuforce setup.  Steve Earl is onstage at the moment.... :P
JEaton
« Reply #2 on: 19 Feb 2012, 09:21 pm »
No way to _enter_ a URL in Squeezebox Server, or do you mean that you can't identify a URL for the stream?
Connect your Touch to your local Squeezebox Server, then pull up the web interface and you can enter a URL under Home > Internet Radio > Tune in URL.
avta
« Reply #3 on: 19 Feb 2012, 09:38 pm »
or try going to mysqueezebox.com. Under the Favorites tab is a place to enter a URL.
Chromisdesigns
« Reply #4 on: 19 Feb 2012, 09:42 pm »
OK, thanks, I'll try that.  Don't know if it will work with the specific streaming tech they are using, but worth a try.
Chromisdesigns
« Reply #5 on: 19 Feb 2012, 09:47 pm »
Nope, doesn't work.  Too bad -- the streaming version they are using isn't recognized by SB server -- it tries to start, then just stops and goes back to 0.00 and the "stopped" icon.
Here's the link, if anyone else wants to try:
http://www.warrenhellman.org/warren/stream.shtml
JEaton
« Reply #6 on: 19 Feb 2012, 09:49 pm »
That's just a URL for a web page. It's streaming a flash video, which can't be played by Squeezebox.
Chromisdesigns
« Reply #7 on: 19 Feb 2012, 09:54 pm »
I think it's HTML 5, actually.  In any event, SB won't play it.
I wonder if anyone's written a plug-in for this kind of thing?
Added:
others have wondered the same thing, evidently: http://forums.slimdevices.com/showthread.php?t=80885
