Wall treatments in my new condo
0 Members and 1 Guest are viewing this topic. Read 1574 times.
milford3
« on: 17 Feb 2012, 08:21 pm »
Moved from my big house to a condo.  Wall treatments are in order.  I will be installing just front and rear panels. No bass traps.  I need just advice on two things.  A good manufacturer and if I should go with 2 inch thickness or 4 inch thickness.
bpape
    • Sensible Sound Solutions
Re: Wall treatments in my new condo
« Reply #1 on: 17 Feb 2012, 08:29 pm »
In general, I think it's a mistake to not do broadband bass control.  That said, at least from a decay time standpoint, the 4" panels will provide a bit of it in addition to whatever else you're shooting for.
Bryan
Ethan Winer
  • Audio expert
« Reply #2 on: 18 Feb 2012, 06:02 pm »
I agree with Bryan that two inches thick is the better choice. And if you can put some of those panels near to corners, they'll help to absorb bass even if they don't straddle the corners.
--Ethan
glynnw
  • I have tin ears.
« Reply #3 on: 18 Feb 2012, 07:24 pm »
You might look at these guys for DIY supplies.
http://www.atsacoustics.com/cat--ATS-Acoustic-Panels--100.html
 Have received prompt shipments and fast answers to email on several occassions.  I made 2" panels for walls (and a couple on the ceiling) and am very pleased, although some friends now think my room is overdamped.  It is a lot of work covering and hanging them yourself, but savings are significant.
audiotom
  • Ground control to Major Tom
    • for everything music
« Reply #4 on: 19 Feb 2012, 07:41 pm »
I'll give a strong recommendation
Real traps and gik have great products and knowledgeable staff
You will do great with either
