DAC's with (2) SPDIF + (2) optical inputs
0 Members and 1 Guest are viewing this topic. Read 2767 times.
gooberdude
« on: 17 Feb 2012, 12:25 am »
I'm shopping for a new dac, $1K-$1500.  (4) inputs preferred:  2 SPDIF & 2 optical.
Looks like the Antelope Zodiac would be fine but its on the high side pricewise.  I'm wondering if anyone knows of other good options. Used is OK.
I currently have a Tranquility and a new grant fidelity dac-11 but am planning a 2nd system with the dac-11.  Don't think i'll need or want usb anymore, probably get a converter for the mac mini & run spdif cable since the dac is 15' away.
Both the cable tv & PS3 only have optical outputs and require 15' cables.  The mac mini sits below that gear & also needs a long cable.  A sacd player is on the other side of the room 1-2 meters from the dac.  Its an odd set-up due to an audio system on one end & video on the other.  Only the sacd is used for serious listening but all sources play thru my speakers.
hdmi cables are limited in length, esp when using a switcher box, and this keeps 3/4 of my sources far from the dac.
any assistance is appreciated.
matt
golfugh
  • Dead Can Dance - Into the Labyrinth
Re: DAC's with (2) SPDIF + (2) optical inputs
« Reply #1 on: 17 Feb 2012, 12:31 am »
Wyred4Sound DAC1 ($999) and DAC2 ($1499)
gooberdude
« Reply #2 on: 17 Feb 2012, 12:46 am »
Thx!  The Bryston BDA-1 has a ton of inputs too.
emac
« Reply #3 on: 17 Feb 2012, 01:23 am »
You can try the Dual Beast DAC from Ross Martin Audio, which starts at $280 via fleebay.  Got one recently with some of the upgraded opamps, OPA627's and OPA1602's, and it sounds pretty good to my ears.  Can't compare it to DACs in the $1000-1500 range though since I haven't heard any in my own home.
PSB Guy
« Reply #4 on: 17 Feb 2012, 02:32 am »
Audio By Van Alstine Vision EC ($1299) and Vision EC Hybrid ($1999).
Cornelis
pardales
gooberdude
« Reply #6 on: 17 Feb 2012, 03:13 am »
Good to know there are choices out there.
That's a good deal pardales.   :thumb:
Stu Pitt
« Reply #7 on: 17 Feb 2012, 04:51 am »
Rega DAC.  Mine sounds awesome to my ears, as usually everyone's gear sounds great to their ears  :lol:
