0 Members and 1 Guest are viewing this topic. Read 6636 times.
I had to rebuild my computer at the end of December because after 7 years the motherboard caps leaked.You will have to switch to DDR3 memory but memory is so cheap now that it is a not a factor.What I bought:Asus P8H67-V REV 3.0, if you are not a gamer you don't need a graphics card with this boardhttp://www.asus.com/Motherboards/Intel_Socket_1155/P8H67V/Intel I7 2600K, get the K series because both the 2600K and I5 2500K have Intel’s HD Graphics 3000 and the core is unlocked.The Sandy Bridge Review: Intel Core i7-2600K, i5-2500K and Core i3-2100 Tested4 GB Crucial DDR3 1333 ram (CT2KIT25664BD1339)- why buy anything else? I can always add more if I need it.Sapphire Vapor-X HD6770 - I need to run 2 VGA monitors at the same time and this card does it.http://www.sapphiretech.com/presentation/product/?cid=1&gid=3&sgid=1073&lid=1&pid=1193&leg=0PC Power and Cooling 600W - you might need a new power supply, this one is quiet, has modular cords and has rebates.http://www.newegg.com/Product/Product.aspx?Item=N82E16817703036Wayne
It's hard to reuse obsolete memory
You have that right. I have 2 GB (4 - 512MB 184-pin DIMM) DDR PC3200 CL=3 Unbuffered NON-ECC DDR400 2.6V that I am going to sell on CraigsList for $15 (unless somebody here wants them).
I need an Asus P5Q SE PLUS or similar.
Also no new motherboards have IDE ports..
Why would you go with an ancient Socket 458 board?
Yes, some still do. The Asus P8H67-V REV 3.0 I suggested does, I use older IDE drives for storage and backup.If you prefer an AMD processor to save money a new AM3+ board with IDE, SATA, and USB3 is the ASUS M5A88-V EVO. Actually the P5Q SE Plus uses an Intel Socket 775.
What are some other ASUS options?
You're not giving anyone much to go on. What's the problem with the ASUS motherboard suggested above?Is there some particular set of features that you're looking for? Some particular peripherals or old cards that you need to reuse?What size is your old case? Can it accept a full-sized ATX motherboard?What is the rating of your power supply?
