Help me make up my mind
0 Members and 1 Guest are viewing this topic. Read 16202 times.
pansixt
Re: Help me make up my mind
« Reply #40 on: 25 Feb 2012, 03:49 am »
My dilemma, or question is ST70 with a T-8 or ST70 with a Fet Valve Hybrid Preamp?
What do you think Dean or Frank? Or anyone. How would the Fet Valve Hybrid Pre-
work with an ST70 (or with the Ultimate 70 upgrade) as opposed to a T-8?
James
I.Greyhound Fan
« Reply #41 on: 25 Feb 2012, 05:39 am »
I would go with the FET Valve Preamp.  I have an Ultra II Preamp and did an in home comparison and reivew of the 3 FET Valve gear.  The FV Preamp is in a whole different league than the Ultra II which IMO is much better than the T-8.  The FV has better bass, detail, transparency and just sounds smoother.
I would consider going with a FET Valve 400R amp and the T-8!
Lefty052347
  • AVA Associate
« Reply #42 on: 25 Feb 2012, 09:07 am »
I would recommend the U70 upgrade and the T-8.  The difference between the an ST70 and U70 is greater than the T-8 and FET Valve.
I am currently using a Ultra II in combination with an Ultravalve.
Dean
simon wagstaff
« Reply #43 on: 25 Feb 2012, 01:45 pm »
Don't know about the ST-70 but I love my U-70. If it has enough power it will be a very satisfying amplifier.
pansixt
« Reply #44 on: 25 Feb 2012, 04:37 pm »
Dean
That has been the original plan for some time. And more affordable for me right now. But then I heard the 400R and FET Valve Pre in Denver and it got me thinking.
Thanks Dean.
James
trebejo
« Reply #45 on: 26 Feb 2012, 07:43 am »
If you don't have a problem with the heat from the tubes, then I would encourage you to try the upgrade from the ST70 to the U70, since the latter is a really really nice amp.
Brett Buck
« Reply #46 on: 26 Feb 2012, 09:13 am »
   If you are going to run a stock St-70 a great preamp will help but will not be correcting the biggest problem. I grew up listening to a stock ST-70, it's mellow and all, but you want and need the Ultimate 70. Its not an "upgrade" in the normal sense of the word, it's a new amplifier using ST-70 parts and arguably the best tube amp available at any cost. Unless you are trying to build a hi-fi for the Superdome, it has more than enough power with any rationally efficient speaker.
    Don't worry about the construction, you can get Frank and Co to build it but I put mine together with no problems in a long evening. I took far more time stripping and cleaning up the old chassis than I did assembling the new bits.
   Of course, a T8+U70 is a tremendous jump up, to, and the cost is not at all prohibitive by hifi standards.
    Brett
pansixt
« Reply #47 on: 27 Feb 2012, 11:31 pm »
Thanks to all for the input. I am working on the cocoon packaging to send my amp to
Franks for the U-70 build.
I am sure I will be going with the T-8, although they may still have the AvaStar demo
model for sale. Just another thought.
Thanks Again everyone,
James
Devil Doc
  • On the road to Perdition
« Reply #48 on: 14 Mar 2012, 06:37 pm »
So how's it coming, Frank? We gettin' closer? :angel:
Doc
Lefty052347
  • AVA Associate
« Reply #49 on: 14 Mar 2012, 10:08 pm »
Doc,
Yes.
Devil Doc
« Reply #50 on: 15 Mar 2012, 07:14 pm »
Taciturn Minnesotans. I thought it was just us New Englanders. Anyway, Lefty was funnin' me. It's on its way. Exactly when they said it would be. Now that's service. Oooo-Rah!!!
Doc
Devil Doc
« Reply #51 on: 20 Mar 2012, 05:37 pm »
It has arrived and a day early,too. Unfortunately it's my wedding anniversary. So, I can't spend too much time listening. :cry: I hooked it up, though and listened to Jerry Jeff's Ultimate Collection CD with cold tubes. All I can say is that I hear a lot more detail than I realized was here. For instance, on Mr. Bojangles the drummer plays the bell on his cymbal. I used to think it was with the tip of his stick. It's obvious, now, that it's being played with the barrel of the stick. There's other things. I can play my system much louder with out grinding my teeth. Well, i got to go pay attention to the Ol' Lady. But before I go I'd like to say, and I know Frank doesn't like his fans to get carried away, but If you don't at least audition his stuff, you got to be out of your mind.
Doc.
pansixt
« Reply #52 on: 22 Mar 2012, 12:52 am »
That's great to hear Doc.
About the anniversary and the T-8 review. Give us more input when you get time.
Every time I re-configure my system, I preview with The Byrds Sweetheart of the Rodeo vinyl. It's a thirty plus year tradition. But the Jerry Jeff sounds enticing also.
Hopefully, my Dyna amp arrived in Woodbury by now and will soon undergo the U-70 Rebuild.
Dean, if you catch this, let me know any progress on my ST-70/Ultimate 70.
James
avahifi
    • http://www.avahifi.com
« Reply #53 on: 22 Mar 2012, 05:10 pm »
James,
We received your st-70 in good condition.  Actually the chassis and cover look great.
Frank will bench check the amp prior to the upgrade as the first step in the process.
Dean
trebejo
« Reply #54 on: 23 Mar 2012, 05:33 am »
Oooh, somebody is gonna get a very nice aaaamp...  :eyebrows:
simon wagstaff
« Reply #55 on: 23 Mar 2012, 01:30 pm »
Yepper! :D
pansixt
« Reply #56 on: 24 Mar 2012, 01:59 am »
Thanks Ya'll. Don't want to hijack the thread. Dean, Frank, PM Me.
Back to the thread.
DOC Help me out here with a T-8 Review.
Devil Doc
« Reply #57 on: 24 Mar 2012, 12:31 pm »
I'm no good at reviews, but I will say it's smoother, more detailed and just plain better sounding than the 20 yr old PS Audio 6.0 that it replaced. I did audition, in my home, a pre-amp that will go unnamed, but it cost more than twice as much, inverted polarity (hint) and didn't sound as good, to my ears. With the addition of the T-8+ and my Insight+250, I really feel I've finally reached the point where I would have to spend a ton more money to achieve very little improvement. BTW, It gives new life to my phono-pre, giving the entire analog system much better defined bass. I thought I needed to upgrade it, but now I'm not so sure.
I can't see how you could go wrong by purchasing one. I doubt you'll send it back.
I can't wait to check out the headphone amp that's included and was wondering if it had enough power to drive the 600 ohm cans I'm considering acquiring.
Doc
Edited to add: AVA equpment is much more attractive in person. The Photos on the site don't do them justice.
