6B-SST2 vs. 4B-SST2
0 Members and 1 Guest are viewing this topic. Read 3409 times.
SoundGame
6B-SST2 vs. 4B-SST2
« on: 2 Feb 2012, 08:56 pm »
I was just comparing the specifications in the manuals that are found on the Bryston site for the 6B and the 4B.  This raised a couple questions:
1) The NOISE ratio quoted for the 6B (@ 29db / 23db gain) are slightly better than the 4B as follows:
    6B: 112db @ 29dB gain & 115 @ 23 dB gain, whereas;
    4B: 110db @ 29db gain & 113 @ 23 db gain.
How does the 6B actually outperform the 4B, when I would think their designs are identical and if anything, given space contraints, the 6B should be the amp that would face compromises? :scratch:
2) The 6B consumes 2100 watts for 300 wpc into 8 ohms (which is 17.5 Amps) - though the max. consumption for 4 ohms is not quoted it would be over 3500 watts and this would need over 30 Amps.  How would this ever be achievable, given that it appears it's designed for a standard 15A outlet? :scratch:
SHV
Re: 6B-SST2 vs. 4B-SST2
« Reply #1 on: 2 Feb 2012, 09:27 pm »
I have a 6B SST and 7B SSTs (bridged 4B) and the chassis design is very different.  The 6B has three independent shielded modules that "plug" into the main chassis.  (It also is a back breaker to move. :>)  Whether this increased channel isolation improves the "numbers", I have no idea.
Phil A
« Reply #2 on: 2 Feb 2012, 10:24 pm »
My 6BSST too - heavy but has handles.  It also uses a 20 amp IEC even though a 15 amp design
SoundGame
« Reply #3 on: 3 Feb 2012, 12:52 am »
Don't get that Phil...how does it use a 20amp IEC if it's a 15 amp design - did you mod-it or are you just using a heavier power plug and a 20 amp wall outlet and circuit?
I'd expect it to be at least a 3rd heavier than the 4B, which already breaks my back at 60lbs.  The 6B should be in the 90lb range - though I haven't checked the specs.
If it's on a 15 amp circuit, you probably could never get it to clip consistently while running 4ohm speakers because the panel breaker would trip....
Phil A
« Reply #4 on: 3 Feb 2012, 02:04 am »
No did not mod it.  My old 14BSST was the same - 20 Amp IEC
Phil A
« Reply #5 on: 3 Feb 2012, 02:18 am »
My 6BSST sits behind a couch and I use it to drive the center and rears:
