Audio/Video Gear and Systems
Open Baffle Speakers
JohnR
Old Sansui woofers reborn as OB bass augmentors
0 Members and 1 Guest are viewing this topic. Read 4328 times.
Poultrygeist
27 Jan 2012, 08:07 pm »
I scavenged these 17 inch woofers from some Sansui SP-X9700 4 way speakers which were in sad shape. Everything was blown save for the woofers. Since they had F-Range stamped on the magnets I gave them a listen and they were surprisingly good. They seem just as efficient as Alphas and go a tad lower. I re-dyed them with PE cone paint and use them to add bass to my assortment of FR speakers, cutting them off at 80hz.
I wouldn't doubt that there are many other old Japanese speakers which contain decent FR woofers.
Bemopti123
Re: Old Sansui woofers reborn as OB bass augmentors
27 Jan 2012, 08:17 pm »
Great idea in recycling instead of just using it as landfill stuffing.
Poultrygeist
Reply #2 on:
27 Jan 2012, 09:39 pm »
Sadly the landfill claimed the Sansui enclosures, two mids, four horns and six tweets -all dead as a door nail.
Who knows I may eventually build some proper H-frames for these old puppies with something vintage on top.
planet10
Industry Participant
Frugal-phile (tm)
Reply #3 on:
28 Jan 2012, 02:56 am »
Good to see. I have a single one of these... waiting for another tomaterialize or find someone that could use a single.
dave
Davey
Reply #4 on:
28 Jan 2012, 03:34 am »
With a baffle that small, it seems you will have considerable front/back cancellation. I would definitely build an "H"-frame around those to create a much more effective configuration.
Dave.
Poultrygeist
Reply #5 on:
31 Jan 2012, 02:09 pm »
Using a baffle this small allows for an easy conversion to H-frames but as is the bass weight is pretty good.
JohnR
