0 Members and 1 Guest are viewing this topic. Read 4973 times.
Just finished building my new Selah speakers. As you can see from these pictures
They are as far out into the room that I can get them.
Would it be of any benefit to provide a few 2 foot high absorb panels behind the speakers? mini corner bass traps? Will this this be any help at all?
They look great!That's not necessarily the ideal place for speakers. The best way to find where you'll get the smoothest LF response is to measure at high resolution using room testing software such as Room EQ Wizard.Any bass trapping is better than none, but in reality you need more than two small traps to get good sound in most rooms. You'll find some Before / After graphs with explanations here:Acoustic Basics--Ethan
I have an iPad spectrum analyzer that may help a little.
a little acoustic on all three walls? Even if it is not great benefit, I will take anything I can get.
On the first post in the conversation, there is a picture of the set-up, if you would be so kind to take a look.
