Do you need your amp on while burning in a preamp?
0 Members and 1 Guest are viewing this topic. Read 3792 times.
schw06
« on: 16 Jan 2012, 01:01 am »
I feel silly asking this question but I am burning in a TRL Dude(preamp) and I'm not sure whether It will successfully burn in without the amp on. Thanks for the input.
David
warnerwh
Re: Do you need your amp on while burning in a preamp?
« Reply #1 on: 16 Jan 2012, 01:07 am »
It wouldn't matter either way but I'd not leave your preamp on all the time. It's be fine just using it for music.
Big Red Machine
« Reply #2 on: 16 Jan 2012, 01:12 am »
I don't believe the actual audio circuits are being worked if the unit is just sitting there in the "on" position.
Did you tell me you were getting a Dude?  Just set the volume to low, put the music on repeat, and come back in 150 hours for the first step.  A work week is 120 hours.
schw06
« Reply #3 on: 16 Jan 2012, 01:15 am »
Pete,
   That's why I bought your awesome interconnects. Thanks for the advice guys.
David
Big Red Machine
« Reply #4 on: 16 Jan 2012, 01:28 am »
Pete,
David
They work well for you?
« Reply #5 on: 16 Jan 2012, 07:36 pm »
David
Hi David,
You don't need the amplifier on to break in a preamplifier. The input Z of the amplifier will load the preamplifier. Just run a signal and you should be fine. A tuner, TV box etc should be fine.
Cheers and good luck.
« Last Edit: 17 Jan 2012, 12:59 pm by Steve »
