HD Tracks 192kHz/24bit flac download only makes static
0 Members and 1 Guest are viewing this topic. Read 2620 times.
fado
Will the BDP-1 play 192kHz/24bit flac files?
Any dynamic solutions for the static?
BrysTony
Re: HD Tracks 192kHz/24bit flac download only makes static
« Reply #1 on: 11 Jan 2012, 04:40 am »
Yes, the BDP-1 plays those files without problem.  What DAC are you using?
Tony
fado
« Reply #2 on: 11 Jan 2012, 05:17 am »
The Eastern Electric MiniMax DAC with Bolder Cable Co level one modifications.
zybar
« Reply #3 on: 11 Jan 2012, 01:50 pm »
Yes it will.
The question is will your DAC?
George
fado
« Reply #4 on: 11 Jan 2012, 02:38 pm »
According to the literature it will - except through the USB connection but I am not using it.  I am checking into this further.
Also, I did not use the "Play Tracks" option at the end of the HD Tracks download.  Could this be the problem?
BrysTony
« Reply #5 on: 11 Jan 2012, 02:47 pm »
fado,
I am not familiar with your DAC; however, I just read a review http://www.dagogo.com/View-Article.asp?bShowUnpublished=&hArticle=798&PageOfArticle=2 that on page 3 says that there is an anomaly when switching from 16/44.1khz to 24/192khz.  Could that be what you are experiencing?
Tony
fado
« Reply #6 on: 11 Jan 2012, 03:11 pm »
Most likely.  I just got a reply from Bolder Cable Co stating that 192 is very hard for this DAC. He mentioned that the DAC chip can do it, but the design of the input switching makes it very difficult. 44.1, 88.2, 96, and even 176 all seem to be able to play with no trouble.
Thank You - I'll check the review.
