0 Members and 1 Guest are viewing this topic. Read 28440 times.
Sorry but it may not be the speaker. It is what is being fed into it. The Maggie will expose all good and evil. I owned MMG and 3As[ still kicking ] for a while back in the day. Older maggies can be bright with some components. sounds like ya need a bit of warmth there in the chain. Try a friends CDP or a tubed Preor buffer and report back. Or a different amp. Synergy baby.charles
What are some popular ways to attenuate the tweeter? Is that what I need to do?Michael
I agree with others that it maybe due to your preamp or DAC. Maggies need careful equipment matching. Tubes go great with Maggies and allow you to tube roll to tailor the sound to your liking.Here's a couple of things to try. First try small changes in placement of the speakers, even 1" front-back or side to side can make a difference. Also try changing the toe in angle. Another thing you can try is swithch the left and right speakers so that the tweeter is on the inside of edge of the speaker. Magnepan recommends that the tweeter be placed to the outside of the speaker but some people find sound better with the opposite.If that does not work try the tweeter attenuation resistors. 1.5ohm's may be too much. Magnepan now has 1 ohm 25 watt wirewound NTE resistors that they would probably send you for free. I recently called them up and got a pair. You can try even lower value's like 0.5 or 0.75 ohms. The lower values attenuate less. Just subtle changes in tweeter attenuation can take away some High Frequency edginess. The are NTE wirewound resistors can be bought from several places.-http://www.moyerelectronics.com/Departments/Products/NTE/NTE-Resistor/NTE-Power-Wirewound-Resistor/25-Watt-Cermet-Power-Wirewound.aspxhttp://www.mcmelectronics.com/product/NTE-ELECTRONICS-25W1D0-/25W1D0http://www.galco.com/scripts/cgiip.exe/wa/wcat/catalog.htmhttp://www.onlinecomponents.com/parametricsearch/passive_resistors_through-hole-resistors.html?p=1
I checked the NTE web site and there are not many companies that carry the NTE wirewound resistors. But it is worth a try to find them locally. Certainly you can try other brands and types. Mundorf makes some nice one's at about $15 each, but you won't get any better sound using them.http://www.madisound.com/about/resistors.php
Stay away from attenuating resistors. They remove a lot of information.Toe them out an inch.Problem solved.
