I need a single channel variable gain stage...
0 Members and 1 Guest are viewing this topic. Read 2005 times.
Russtafarian
  • Typical reaction to the music I play
« on: 5 May 2004, 08:10 pm »
with about 20 db of gain to kick up the LFE level coming out of my Pioneer 563a.  Any ideas on something inexpensive, like for $30-40?  Any simple DIY projects that'll do this?
Rob Babcock
« Reply #1 on: 5 May 2004, 08:14 pm »
You might want to post this in the lab- anything DIY will get a lot more reads there than here.  I don't know of anything you could buy prebuilt for that money, but JohnR or MGalusha are pretty handy with DIY'ing.  I'd ask them.
JohnR
« Reply #2 on: 5 May 2004, 09:55 pm »
This gadget might do the trick:
http://www1.jaycar.com.au/productView.asp?ID=KA1814&CATID=25&keywords=&SPECIAL=&form=CAT&ProdCodeOnly=&Keyword1=&Keyword2=&pageNumber=&priceMin=&priceMax=&SUBCATID=557
A bit more elaborate than you want but it's useful and cheap. Will need a mod to get more gain, I'll have a look at the circuit.
mgalusha
« Reply #3 on: 5 May 2004, 11:10 pm »
Another option: http://www.electronickits.com/kit/complete/ampl/k100.htm
It offers 20dB of gain and has tone controls. Not quite as elaborate of bass management as the kit John listed but not bad for $20. Don't forget you will need a power brick and some kind of case of it (or not ;)) I have purchased from these folks before with zero problems.
mike g
Russtafarian
« Reply #4 on: 6 May 2004, 12:34 am »
That K100 preamp kit looks like it will work.  Thanks!
