0 Members and 1 Guest are viewing this topic. Read 73815 times.
I'm not sure but I think that speaker sniffing is a misdemeanor in the Commonwealth of Pennsylvania. You might want to keep that part to yourself.Have you updated your speaker wires yet? I might have an extra set if you're interested.
Curiosity got the better of me.Mine smell like old socks and pipe tobacco.I knew it was a mistake to let the laundry pile up.
As it stands, the Magnestands are lucid and fast as can be. Once the system is more or less complete I'd love to take them to an audio show to have them compared. Gunn says post mod they have electrostatic speed all the way into the bass region, and I haven't heard anything else so transparent across the full range as these.
Nice thought, but extremely unlikely that any exhibitor would waste even 30 seconds of their precious show time to let you come in and set up your home speakers. Unless of course it was a room rented by Peter Gunn. However a GTG in your area would be an excellent place to show off your beauties. Check the Regional Audiophiles section to see if there's a group in your area, if not, start one.
I find the first part a bit scary. Your speakers think clearly? As for what PG says, take it with a grain of salt. Wood frames and a different crossover aren't going to affect the behavior of the motor - won't change 'speed' or efficiency. Replacing the wire with foil will impact both of those metrics (in opposite directions).I'm glad to read that you're still enjoying them and I have no doubt that they are simply gorgeous.
...The panels aren't that expensive to replace if I messed something up. So after all is settled, I may try the foil mod. Hypex has a new PC controllable digital crossover coming soon. Perhaps when all is said and done, an active system, multiple ncores, foil mod. But as it stands, they give me a huge grin, and I could be satisfied if I never changed a thing. ... money very well spent
